total_comments not reseting
March 01, 2011 12:45pm
  • #1 / Mar 01, 2011 12:45pm
    Cartegraph
    the tag {total_comments} is not reseting when I delete a comment from within the admin panel. Where is this being pulled from in the database? I am running v2.1.3… any ideas as to why this is happening?
  • #2 / Mar 01, 2011 12:55pm
    Cartegraph
    found it, it seems that {total_comments} displays the total number of comments for the user logged in… how do you show the total number of comments for a particular entry?
  • #3 / Mar 01, 2011 1:30pm
    Mark Bowen
    Nope {total_comments} should show the total number of comments for the comment entries tag on all pages.
    That is it will if you place it within the {exp:comment:entries} tag pair. I can see you have the {total_comments} variable at the top of your main code above so what you’re using there is the Global {total_comments} variable.
    Place that variable within the comment entries tag though and you should get what you need.
    Hope that helps a bit.
    Best wishes,
    Mark
  • #4 / Mar 01, 2011 1:33pm
    Cartegraph
    yep, worked like a charm and makes perfect sense.
    Thanks for the reply.
  • #5 / Mar 01, 2011 1:36pm
    Mark Bowen
    No problem at all. Glad that got it sorted for you.
    Best wishes,
    Mark
  • #6 / Mar 01, 2011 3:33pm
    Thanks for the assist, Mark. Please post again as needed.
