Displaying Categories for an Entry
February 28, 2011 12:24pm
  • #1 / Feb 28, 2011 12:24pm
    Cartegraph
    How do you do this?
    I’ve tried the following
    {exp:query sql="SELECT cat_id FROM exp_category_posts WHERE entry_id = '{entry_id}' "}
       {exp:query sql="SELECT cat_name FROM exp_categories WHERE cat_id='{cat_id}' "}
          {cat_name}
       {/exp:query}
    {/exp:query}
    It returns the correct {cat_id} (which there are four entries) values but when {cat_id} is used to fetch the cat_name it just returns the first {cat_name} four times.
    Any Ideas?
  • #2 / Feb 28, 2011 6:35pm
    smartpill
    Instead of all that, have you tried:
    {categories}
    {category_name}
    {/categories}
    If that doesn’t work, post the whole template if you can. I’m not sure a query within a query will work the way you want it to which is probably why your getting repeated data.
  • #3 / Feb 28, 2011 9:11pm
    Cartegraph
    wow was I way over thinking it. Thanks for the reply it worked beautifully. good to know for future reference that nested query’s don’t work though.
    Thanks again, much appreciated.
  • #4 / Feb 28, 2011 9:41pm
    smartpill
    No problem, we’ve all been there. Glad I could help.  😉
