{no_results} not working on exp:channel_entries nested inside {exp:channel_catgegory_archive}
February 26, 2011 6:52pm
  • #1 / Feb 26, 2011 6:52pm
    OutofControl
    Here is the code:
    <div class="accordian">
    {exp:channel:category_archive channel="Tutorials" show="60|65|131|29|122|30" style="linear"}
    {categories}
    <h2 id="{category_url_title}" class="mtl">{category_name}</h2>
    <div class="column_2">
    <dl>
    {exp:channel:entries category="{category_id}&136;" dynamic="no" require_entry="yes" disable="categories|member_data|pagination"}
    {if no_results}<dt><a href="#">There are no {cat_name} submitted yet.</a></dt>{/if}
    <dt><a href="#">{title}</a></dt>
    <dd>
    {body}
    <a href="http://{link_url}" rel="external" title="{title}">Visit homepage</a>
    </dd>
    </dl>
    </div>
    {/categories}
    {/exp:channel:category_archive}
    </div>
    Can anyone see why the no_results doesn’t work? If it is not possible to have no_results work inside the category_archive tag, is there another way around this?
  • #2 / Feb 27, 2011 2:02pm
    John Fuller
    Not sure offhand as I try to avoid this sort of situation due to possible conflicts.  What I generally do instead is to do an embed.  So, put the channel entries tag in a different template and call that template as an embed.  Send the category_id as a embed variable.
  • #3 / Feb 27, 2011 2:53pm
    OutofControl
    Right! That did the trick and in the end helped me simplify the layout on that entire section.
    Thank you very much John
