safecracker: problems customizing a matrix field with playa inside
February 25, 2011 1:19am
Subscribe [4]
  • #1 / Feb 25, 2011 1:19am
    aircrash
    I have a matrix field that contains a playa field, and I’m trying to customize the matrix display. I was initially just going to copy the source of the default matrix display and use that to hard-code a customized version, but I have a playa field in the matrix that I need to keep dynamic. Is there a way to leave the playa field dynamic while hard-coding the rest of the matrix code around it?
    Also, I’m not able to add a row to the matrix. I’m getting a bunch of “ReferenceError: Can’t find variable: jQuery” errors
  • #2 / Feb 25, 2011 11:11am
    Sorry, you lost me: how does SafeCracker come into play here? Are you having the same problem when doing this via the control panel?
  • #3 / Feb 25, 2011 11:47am
    Rob Sanchez
    To get all the requisite Javascript+markup for a Matrix and/or Playa field to function properly, you need to use the {field:your_field_name} syntax.
  • #4 / Feb 25, 2011 12:24pm
    aircrash
    @Ingmar, I’m using safecracker to build an entry form that contains the matrix/playa combination. I want to alter the matrix code to get rid of the table layout, so that it displays properly (I have too many fields to display in a horizontal table format). The matrix works fine in the control panel, but I need to allow visitors to create entries via safecracker. I’m using 2.1.3, build 20101220.
    @Rob, so there’s no way to alter the way the matrix code is displayed?
  • #5 / Feb 25, 2011 12:35pm
    Rob Sanchez
    Not if you want it and its celltypes to function properly. I think the best thing to do is style it with CSS.
  • #6 / Feb 25, 2011 12:51pm
    aircrash
    Thanks. I’m having the jquery issue even when using the {field:your_field_name} syntax.
  • #7 / Feb 25, 2011 4:26pm
    aircrash, are you using 1.03 or 2.0 as far as SafeCracker is concerned?
  • #8 / Feb 25, 2011 5:24pm
    aircrash
    1.03. Haven’t had a chance to upgrade yet.
    I noticed in the release notes something about the catchall field being removed. Does this mean that my existing catchall fields will stop working?
  • #9 / Feb 27, 2011 2:29pm
    Greg Salt
    Hi aircrash,
    In fact there are no functional changes in Safecracker 2.0 though the catchall fieldtype is not now bundled.
    Cheers
    Greg
  • #10 / Mar 01, 2011 11:29am
    Rob Sanchez
    You can now download the Catchall fieldtype from Devot:ee. This replaces the old safecracker_catchall fieldtype. There are instructions for updating at the bottom of the page here: http://devot-ee.com/add-ons/catchall/
  • #11 / Mar 02, 2011 10:01am
    Thanks for the assist, Rob.
    Aircrash - let us know if the info from Rob helps.
