category display order wrong + images don't appear
February 16, 2011 11:36pm
  • #1 / Feb 16, 2011 11:36pm
    markoneil
    Hi, I’ve got two problems—at least may be a bug that can be fixed with a version upgrade but I want to be sure before I go to the trouble. According to https://secure.expressionengine.com/download.php I have Version: 2.1.3 - Build: 20101220, purchased on 1-11-2011.
    (1) Category Order cannot be changed with up and down arrows
    (2) After being uploaded, image files do not display when called to a template from an entry tag. Instead the image url appears. A visit to the displayed url confirms that the image is there.
    Can these things be fixed with an upgrade? And if so, how do I upgrade? If I download from https://secure.expressionengine.com/download.php will that be the latest version or the one I already downloaded?
    Would appreciate a quick response—I’ve been trying to resolve this for quite some time and tonight I have to send something to my client.
    thanks
  • #2 / Feb 17, 2011 1:51am
    Cheif
    Can you show us what’s happening in your code via Firebg screen shot or something as well as the pertinant code in use.
    THere is a bit of a bug (of sorts) with thumbnail creation with images but really a bit more SPECIFIC data to work with 😊
  • #3 / Feb 17, 2011 3:55am
    markoneil
    Here is a screen grab showing the portion of the page that is affected:
    http://www.newsite.diverseandresilient.org/screen.html
    The url running off the page at the right is supposed to be a photograph.
    This is the code that produces that result:
    {exp:channel:entries channel="{channel}" limit="1"}
    <div id="photo">{photo}<!-- end #photo --></div>
    It does not happen if I replace {photo} with an image tag that calls the image from the URL shown in the above screen shot.
    The thumbnail is showing up fine in the Publish form.
    thanks
  • #4 / Feb 17, 2011 3:10pm
    That bug should have been fixed in the Beta, yes.
    Can you show us how you’re calling them, a bit of code, perhaps?
    how do I upgrade?
    Just download the Beta from the webshop (download the latest version of 2.1.3 will provide you with a radio button on the licensing details page allowing you to download the beta instead) and perform a version update like you always would.
  • #5 / Feb 17, 2011 5:53pm
    markoneil
    The code is in the excerpt shown above your reply. And here is the css:
    #photo {
        margin: 0 0 0 80px;
        padding: 0px;
        width:250px;
        float:left;
        text-align:right;
        border:0;
  • #6 / Feb 18, 2011 3:59am
    markoneil,
    You need to use the <img> tag in combination with the {photo} custom field. Like this
  • #7 / Feb 18, 2011 2:56pm
    markoneil
    Thanks, John! All better!
    And I’ll consider the category order problem solved, since that just requires an upgrade.
    take care
  • #8 / Feb 18, 2011 3:02pm
    Very glad to see that you’re all set. Please post again as needed.
