Problem saving entryid list to a session
February 16, 2011 9:05pm
  • #1 / Feb 16, 2011 9:05pm
    chilli_group
    Hi All,
    Developing a Real Estate website and have everything setup except this one part:
    Having a problem with an entry_id list that I’m trying to save to a PHP Session and advanced conditionals.
    Here is the code i’m using to try save a php variable.
    $searchids = '{exp:channel:entries channel="properties" dynamic="no" ' . $searchquery . ' search:property_sold="NO"}{if property_price > ' . $price_min . ' AND property_price < ' . $price_max . '}{entry_id}|{/if}{/exp:channel:entries}';
    $price_min & $price_max are getting the GET value from the URL
    If I perform the same code without the {if} statements, it will save the list fine, but because EE parses the ADVANCED CONDITIONALS last, it doesn’t work.
    I’m using this variable to then save to a session and using ‘entry_id’ list on the individual property pages to create NEXT & PREVIOUS properties links based on the search done on the previous page.
    Any ideas to get around this?
    Thanks for your help in advanced.
  • #2 / Feb 17, 2011 10:07am
    Hi, chilli_group. Have you considered using the query module for this?
  • #3 / Feb 17, 2011 6:32pm
    chilli_group
    I did try this, but couldn’t get the PHP working inside the Query Module? Is there a trick to this?
    This is what I’ve tried:
    {exp:query sql="SELECT entry_id  FROM exp_channel_data WHERE field_id_17 = '<?php echo $price_min; ?>'"}
    {entry_id}
    {/exp:query}
    But it returns :
    Error Number: 1064
    You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘’%’ at line 1
    SELECT entry_id FROM exp_channel_data WHERE field_id_17 = ‘
    Filename: modules/query/mod.query.php
    Line Number: 181
  • #4 / Feb 18, 2011 3:56am
    Are you running PHP in Input? Does it work when you hardcode $price_min, as it were?
  • #5 / Feb 20, 2011 7:42pm
    chilli_group
    Hi Ingmar,
    Yeah, PHP is set at input. And yes, when I put in a value (eg. ‘3000000’) it works fine, and I can echo $price_min without problems too.
    any ideas?
  • #6 / Feb 21, 2011 2:16am
    chilli_group
    Ok, worked it out. Ended up doing native SQL query though PHP….
  • #7 / Feb 21, 2011 10:56am
    Sometimes that’s just easier. Don’t hesitate to post again as needed.
