Struggling to get relationships to work..
February 16, 2011 3:37pm
  • #1 / Feb 16, 2011 3:37pm
    CHIEF
    Im sure this is much easier than I am making it out to be.
    I have two Channels:  “product” + “application”
    In a product page, I would like a link to its related application.  So i have created the relationship custom field in the product channel, where there isa drop down displaying the applications.
    I just cant get it to display anything.. not even if I do a conditional to check for no_related_entries.
    here’s my code in the product template, any help would be greatly appreciated.
    {exp:channel:entries channel="product" dynamic="no" disable="categories|member_data|pagination"}
    {related_entries id="application"}
    {app-name}
    {if no_related_entries}
      <h2>No Related Entry Available</h2>
    <p> {/if}</p>
    <p>{/related_entries}
  • #2 / Feb 17, 2011 3:53am
    mark_chief,
    Are you using any custom statuses?
    Any dates in the future?
    You are missing the closing channel:entries tag above. IS this the case in your template?
    {exp:channel:entries channel="product" status="not closed" dynamic="no" disable="categories|member_data|pagination"}
    {title}
    <p> {/if}</p>
    <p>{/related_entries} <br />
  • #3 / Feb 17, 2011 4:51am
    CHIEF
    Hi, sorry, it is closed in the template, just not in the above example.
    v2.1.3- Build:  20101220
    No custom statuses.
    Is it correct that the id=“application” is the name of the channel, and {title} is a custom field in that channel?
  • #4 / Feb 17, 2011 3:20pm
    No, the id= field should be the field name of the actual “relation” field. It would depend on what you have named it.
  • #5 / Feb 17, 2011 7:54pm
    CHIEF
    Maybe using the relationship method will not work for what I am trying to achieve.
    Id like to be able create a link to a products application in the template.
    I.e Product 1 is linked to application 1.
    Link:  “View this product’s related application”
    Is this possible?
  • #6 / Feb 17, 2011 9:43pm
    narration
    mark_chief, it will work fine - what you want is exactly what database relationships are meant to do, and that’s what EE relationships implement.
    All you have to do is what John suggested: name the Relationship field you made in Product as the id for the related_entries tag.
    Here’s how your code fragment needs to look, given I’ve named the relationship field in product as prod_app. Tests fine on some dummy data, plus or minus a little formatting work.
    Product is {prod_name}:
    {related_entries id="prod_app"}
    Yes, {app-name}
    <p>{/if}</p>
    Regards,
    Clive
  • #7 / Feb 18, 2011 5:54am
    CHIEF
    Thanks Clive,  You were correct i was missing the part where I had to name the relationship field.  It wasnt very clear in the docs. All is working now.  Thanks everyone else too!
  • #8 / Feb 18, 2011 6:18am
    Glad to see you’re all set. Please post again as needed.
