Forum thumbnails not working
February 13, 2011 9:15pm
Subscribe [5]
  • #1 / Feb 13, 2011 9:15pm
    eeart
    On our forum uploaded images are not being automatically resized to thumbnails.
    We have set “Use Thumbnails of Uploaded Images in Posts” to Yes. Image Resizing Preferences is set to ImageMagick and the path is set correctly. It doesn’t work with GD either, which is installed.
    In mod.forum_code.php the resizing happens here:
    $this->EE->load->library('image_lib', $res_config);
    if ($this->EE->image_lib->resize())
    But $this->EE->image_lib->resize() is false, so it doesn’t go through with the resizing.
    What could the reason of this be?
  • #2 / Feb 13, 2011 9:21pm
    eeart
    Mmm, if I look in Image_lib.php I find this:
    function resize()
        $protocol = 'image_process_'.$this->image_library;
        if (preg_match('/gd2$/i', $protocol))
            $protocol = 'image_process_gd';
        return $this->$protocol('resize');
    This looks like it would only accept GD 2 ???
    If I set Image Resizing Preferences to GD 2 then $protocol here is still “image_process_imagemagick”.
    If I hack in the line $protocol = ‘image_process_gd2’ the image gets resized on the forum, but the colors are not right.
  • #3 / Feb 14, 2011 8:25am
    Hi, eeart.
    Can you tell us which version/build of EE2.x you’re using? See EEWiki:// HowTo Determine My EE Version
  • #4 / Feb 15, 2011 1:20am
    eeart
    We’re on EE 2.1.3 build 20101220
  • #5 / Feb 15, 2011 3:31pm
    Do you have access to GD2? When you run the server wizard, what results do you get?
  • #6 / Feb 15, 2011 3:41pm
    eeart
    I ran ee_wizard and everything in the Supported column says Yes.
    But I want to keep Imagemagick as our Image Resizing Protocol.
  • #7 / Feb 16, 2011 12:13am
    eeart,
    What version and build of the Discussion Forum are you using?
    Let’s test ImageMagick while we are at it
    Create a file call imtest.php with the following content. Upload it to your root
    <html> <head> <title>Test for ImageMagick</title> </head>
    <body> <?
    function alist ($array) {  //This function prints a text array as an html list.
      $alist = "<ul>";
      for ($i = 0; $i < sizeof($array); $i++) {
        $alist .= "<li>$array[$i]";
      $alist .= "</ul>";
      return $alist;
    exec("convert -version", $out, $rcode); //Try to get ImageMagick "convert" program version number.
    echo "Version return code is $rcode
    "; //Print the return code: 0 if OK, nonzero if error.
    echo alist($out); //Print the output of "convert -version"
    ?> </body> </html>
    load the page up in your browser
    If you have access to “convert,” you will get a return code of 0 plus two or three lines of text, reporting the version and location of ImageMagick.
  • #8 / Feb 16, 2011 1:17am
    eeart
    Imagemagick works fine on other things. The result is:
    Version return code is 0
        * Version: ImageMagick 6.2.8 10/20/10 Q16 file:/usr/share/ImageMagick-6.2.8/doc/index.html
        * Copyright: Copyright (C) 1999-2006 ImageMagick Studio LLC
  • #9 / Feb 16, 2011 2:12pm
    Quick question - are you using a standard forum template?
  • #10 / Feb 17, 2011 4:25pm
    eeart
    We do use the default forum template but it has been modified.
  • #11 / Feb 18, 2011 3:37am
    eeart,
    Before we go in for a look can you quickly switch to another default template and see if issue persists?
  • #12 / Feb 18, 2011 12:19pm
    eeart
    Changing the forum theme does not make a difference.
    We are now also getting an Internal Server Error when resizing images in CP. If I change the Image Resizing Preference from ImageMagick to GD the error goes away and the image gets resized.
    But on the forum GD doesn’t work either; the image becomes all blue.
  • #13 / Feb 19, 2011 2:27pm
    Greg Salt
    Hi eeart,
    Can you please confirm the Discussion Forum module version and build you have installed? Are thumbnails created properly and working elsewhere within your site?
    Cheers
    Greg
  • #14 / Feb 20, 2011 6:40pm
    eeart
    Discussion Forum 3.1.2
    Yes and no:
    1. Resizing is working perfectly with member photos (using ImageMagick) and in my own scripts (both GD and ImageMagick work)
    2. In CP resizing an image in the File Manager results in an “Internal Server Error” when the preference is set to ImageMagick. If I change it GD this works fine.
    3. In the forum image attachments don’t get resized at all when set to ImageMagick, but if I set it to GD images are resized and become blue (see attachment)
    We want to keep it on ImageMagick as we have an area on the website where members can upload very large images and this doesn’t work with GD.
  • #15 / Feb 21, 2011 10:18am
    You mentioned GD, do you have GD2? They’re different.
