I just changed my system offline template from the default content and now when I log in to my CP, it still shows the system offline page as if I’m logged out? Did I made something wrong? 🙄
February 11, 2011 10:25am
Subscribe [2]#1 / Feb 11, 2011 10:25am
#2 / Feb 11, 2011 12:59pm
Are you logging in as a Superadmin? When you login, what template do you see? Did you set the site to offline? Finally, what version and build of EE are you using?
#3 / Feb 11, 2011 1:07pm
Yes I installed EE, so I’m superadmin by default. When I login to my CP I see the CP’s homepage, and when I enter the front-end home page it still shows the offline template. The “Is system on?” is set to No. I’m using Version 2.1.3 Build 20101220.
If I can somehow convert the offline template to default, maybe things will possibly work out?
#4 / Feb 11, 2011 1:11pm
That probably means you aren’t logged in to the frontend, i.e. the system doesn’t recognize you as a Superadmin. Try going to http://example.com/index.php/member/login and login there.
#5 / Feb 11, 2011 1:43pm
The example.com site actually redirects me to “http://www.iana.org/domains/example/” where there isn’t a login option.
Yeah probably the system does not recognize me as a logged in Superadmin, but I wonder how in the first place that can happen!
#6 / Feb 11, 2011 1:51pm
Yes, I meant for you to replace example.com with your own domain name, of course…
#7 / Feb 11, 2011 2:27pm
Ah ok. I replaced it, logged in and now it works!
#8 / Feb 11, 2011 3:46pm
You probably just weren’t logged in before. Sounds like you’re OK now.. Don’t hesitate to post again as needed.
