So my overall goal is to keep my channel:entries tags inside my template files and to move the contents of the channel:entries tag into various partials. What I’m trying to avoid is having duplicated markup for simple variations of the channel:entries tag, which varies with the uri segments. I’ve tried to do this with conditionals wrapped around the entires tags and also using embed tags and this Homegrown Partials plugin , but none have done the trick.
Here is a piece of code that illustrates what I’m trying to do.
{if segment_2 == ""}
{exp:channel:entries
channel="events"
disable="categories|category_fields|member_data|pagination|trackbacks"
dynamic="no"
show_future_entries="yes"
show_expired="no"
require_entry="yes"
limit="1"}
{exp:partials:get name="main_event"}
{if:else}
channel="events"
require_entry="yes"
limit="1"}
{/if}Where
{exp:partials:get name="main_event"}is the piece that renders the partial. Whenever I try now the tags within the partial return as plain-text. Again, I realize this code is technically incorrect, but I’m just using it to illustrate what my goal is. Any help would be appreciated!
