Dedicated xserve mini mac installation problems
February 10, 2011 12:15pm
  • #1 / Feb 10, 2011 12:15pm
    I’m totally new to EE2. We bought it for a 30days trial like I’m do a trial
    on Drupal. Installing Drupal 7 was no problem at all, this takes only 2 hours…..but now Installing EE2 ... ??????????? thats another question. So I have a problem!
    How can I install EE2 to a xserve mac mini server osx 10.6 locally?
    I found the same question on the forum but NO answer. Following the installation handout, step1 is no problem. But step 2…renaming the “system"folder give me problems and this is only step 2 ! Any solution or tips ?
    The /librray/webserver/documents is ok and the webservices and dns are ok and running.
    Best Regards,
    Marc
    [Mod Edit: Moved to the EE 2 Technical Support forum]
  • #2 / Feb 10, 2011 4:32pm
    If you have a working web server with PHP and a MySQL db working locally this should be no problem.
    Please follow these instructions. What issues are you having with renaming the “system” folder? Note that this step is fully optional so you might want to skip it at this point, seeing as how this is a local install.
  • #3 / Feb 11, 2011 6:55am
    OK, found my mistakes. Here my solution:
    1. Install Mamp and create mysql database, installs PHP etc…
    2. go to /applications/mamp/htdocs and create a folder Expressionengine
    3. copy all downloaded installation files to that last folder
    4. copy folder ee-wizart to that last folder
    5. running browser: http://localhost/Expressionengine/system
    The first mistake was that there is a system folder in the root path of the xserver installation and this has nothing to do with the system folder off EE2. The system folder in the installation procedure of EE2 is the one installed in /applications/mamp/htdocs/Expressionengine and NOT the system folder of the server.
    Problem solved up to now.
  • #4 / Feb 11, 2011 7:29am
    Glad you were able to figure out what the problem was. Don’t hesitate to post again as needed.
