Help With Guest Comment Posting
February 08, 2011 5:53pm
  • #1 / Feb 08, 2011 5:53pm
    TheBronzePatriot
    I’m back on comments again.  I’m trying to combine both the Pages module and a pages template to use a comment entry form.  It’s driving me nuts, so I’ll post it here.
    Basically what I did was create a channel called “pages” that I would use for announcements and what not, however I wanted to use the Pages Module to shorten the URL’s rather than having a longer URL to them.  Everything works as far as the Pages module showing the right entry but what seems to be happening is that when I am logged in I can post comments to this page however when I am logged out it says I cannot post comments which means my guests can’t.
    Now I did some settings checks and comments are enabled for the entry, I did also check NO for the Require IP in the Security settings, I also made sure that the Guests member group can post comments and that membership was not required to post comments.  I can’t figure out why this is happening.  Before my issue was not being able to post at all and this time I can post but none of the guests to my website can.
    Here is my comment form code (outside of the channel entries tag):
    {exp:comment:form channel="pages" url_title="{segment_1}" dynamic="off" entry_id="121"}
        <label class="rating-comments-label">Do You Have Any Additional Comments?</label>
        <label for="name">Name:</label> <input type="text" name="name" value="{name}" size="50" /><br >
        <label for="email">Email:</label> <input type="text" name="email" value="{email}" size="50" /><br >
        <textarea name="comment" cols="70" rows="2"></textarea>
        <input type="submit">
    {/exp:comment:form}
    Here is my show comment entries code: (outside of the channel entries tag):
    {exp:comment:entries sort="desc" channel="pages" dynamic="off" url_title="{segment_1}" status="open"}
        <div id="comment-left">
            {name}
            {comment_date format="%Y %m %d"}
        </div>
        <div id="comment-right">
            <!-- Start: Insert Rating -->
            {comment}
        </div>
    {/exp:comment:entries}
    Thoughts I had on it were related to my htaccess code that I was using.  That looks like:
    # secure .htaccess file
    <Files .htaccess>
     order allow,deny
     deny from all
    </Files>
    # EE 404 page for missing pages
    ErrorDocument 404 /store/error/404
    # Simple 404 for missing files
    <FilesMatch "(\.jpe?g|gif|png|bmp|css|js|flv)$">
      ErrorDocument 404 "File Not Found"
    </FilesMatch>
    RewriteEngine on
    RewriteBase /store/
    RewriteRule ^(.*)$ /store/index.php/$1 [L]
    # Remove IE image toolbar
    <FilesMatch "\.(html|htm|php)$">
      Header set imagetoolbar "no"
    </FilesMatch>
    I also thought it might be because I am shortening the URL with the Pages Module, but when I am logged in and post comments it posts them to the correct entry meaning that they show up as the entry having comments with it.
    Any ideas?
  • #2 / Feb 08, 2011 8:44pm
    I think you may be confusing the system with your comment form tag by using both the url_title and entry_id parameters. In this case, your best bet might be the entry_id, as if your url_title and page URI do not match, I don’t think the comment module will know which entry you are talking about.
    Again, for the entries tag, I would recommend using the entry_id parameter instead of url_title.
  • #3 / Feb 09, 2011 1:45am
    TheBronzePatriot
    Tried your suggested changes and it still won’t budge.  Strange.  There doesn’t seem to be anything in the template debugger either.
  • #4 / Feb 09, 2011 3:31pm
    What version and build of EE are you using? What error message, exactly, are you getting? Please try without mod_rewrite for the time being, too.
  • #5 / Feb 09, 2011 3:36pm
    TheBronzePatriot
    I am using the latest 2.1.3 build (Build: 20101220).  The error message said that “You are not allowed to post comments” or something along those lines.  When I am logged in I can post comments and I again double checked my settings.  The entry itself receives the comments when I am logged in but tosses the error when I am a guest.
  • #6 / Feb 10, 2011 5:10am
    TheBronzePatriot,
    Have you got a link to the page in question please?
    You seemed to have covered everything regarding permissions
  • #7 / Mar 01, 2011 4:59am
    TheBronzePatriot
    I figured it out.  It turned out to be that comments were not allowed for guests under a MSM set up.  I shortened my htaccess files and now it works.  Took me a while, but I got it.
  • #8 / Mar 01, 2011 3:44pm
    Excellent. Please post again as needed.
