Captcha Issue
February 08, 2011 1:15am
  • #1 / Feb 08, 2011 1:15am
    soulartist
    Someone tried to post a comment, but got this error message. He did input the correct captcha letters.
    I tried commenting and it seems sometimes it goes through, and other times I get the same error message, even though I’ve placed the correct captcha code.
    Here’s a link to the post. Maybe you can test the comment for me.
    http://www.edensart.com/ee/index.php/eden/comments/el_coyote/=
    Thanks for your help.
  • #2 / Feb 08, 2011 3:12pm
    What version and build of EE are you using, are there any extensions? Just posted a comment (feel free to delete) without any problems.
  • #3 / Feb 08, 2011 3:35pm
    soulartist
    1.7.0 build 20101018
    Extensions: I’m not sure what these are. I do use low nospam, which is module. Is this an extension?
    Thanks for posting.
  • #4 / Feb 08, 2011 4:43pm
    soulartist
    I looked in the extensions folder: in addition to low nospam, there is this: extensions/ext.advanced_captcha.php
  • #5 / Feb 09, 2011 1:12am
    soulartist,
    ext.advanced_captcha.php is an extension which gives you the nice coloured captcha as opposed to the brown default.
    I also left a comment without issue.
    Are you logged out of control panel when you are testing your comments?
  • #6 / Feb 09, 2011 2:01am
    soulartist
    Hi John:
    I’m not in the control panel; and I posted a comment when logged out as well to see the captcha code.
    I tried commenting on this post a minute ago, and it went through.
    So, I don’t know what caused the glitch—which may have gone away for some reason.
    Also, isn’t there a way to have the captcha code refresh with a button if the code isn’t clear to the user?
    Thanks again.
  • #7 / Feb 09, 2011 3:39pm
    So this looks like an intermittent issue, then.
    No, but you can simply reload the page.
  • #8 / Feb 09, 2011 4:45pm
    soulartist
    Unfortunately, yes.
    Yes. Maybe this could be a feature request.
  • #9 / Feb 10, 2011 6:10am
    soulartist,
    You might find what you are looking for in terms of another add-on. have a look here
  • #10 / Feb 10, 2011 3:23pm
    soulartist
    Thanks for the link. I’ll look into it.
  • #11 / Feb 10, 2011 3:26pm
    Very good. Let us know what you find out, please.
  • #12 / Feb 10, 2011 3:34pm
    soulartist
    I downloaded the Accessible Captcha extension.
    So, do I simply add this to my extension folder?
    Do I have to remove or disable anything to make this work?
    Thanks.
  • #13 / Feb 11, 2011 4:24am
    Yes after placing the extension file in your /system/extensions/ folder you then reload the Extensions Manager the extension will automatically be available for you to enable.
    There is also a language file which you need to add to /system/language/
    Disable the advanced one if enabled
    EE Docs: Extensions Manager
  • #14 / Feb 11, 2011 2:25pm
    soulartist
    Hello:
    Back to my original post:
    The person who first reported the issue sent me this note:
    i think the glitch is only if name or email is left out on 1st attempt, so the program sends us back to enter the required item, without changing the code word.
    if name and email are put in correctly 1st time around, then of course it works.  I think it is the lack of putting up a new code word which makes the glitch.
    So, is the an issue with ee?
  • #15 / Feb 11, 2011 3:39pm
    soulartist
    Yes. That worked, but now there is the legacy wording.
    Is there a way to remove the ‘please enter the word . . .”
