Problem saving a template with php tags inside
January 30, 2011 11:17pm
  • #1 / Jan 30, 2011 11:17pm
    Eric Snyder
    When I save a template that contains php tags it gives me the dreaded:
    500 Internal Server Error
    The request was not completed. The server met an unexpected condition.
    the worst! That error is usually hard to get good info from.
    If I save the template as a file using an editor and an FTP client the page loads fine and the php logic runs fine.
    Digging in a bit…if either of these lines is in the template when I save the template it throws that 500 error:
    $result = $this->EE->db->query("SELECT * FROM exp_sites WHERE site_id = 1");
    or
    $result = $this->EE->db->query('SELECT  s.*,
            t.*
            FROM exp_structure AS s
            LEFT JOIN exp_channel_titles AS t ON s.entry_id = t.entry_id
            LEFT JOIN exp_category_posts AS c ON s.entry_id = c.entry_id
            WHERE s.dead NOT LIKE "root"
                AND c.cat_id = 5
                AND t.status = "open"
            ORDER BY s.lft asc');
    Any ideas?
  • #2 / Jan 31, 2011 3:59pm
    Sounds like a possible intervention by mod_security. Can you check with your host? What version and build of EE are you running?
  • #3 / Jan 31, 2011 4:14pm
    Eric Snyder
    What would I be looking for?
  • #4 / Feb 01, 2011 2:38am
    Greg Aker
    Eric,
    Ask your server admins/hosting company if they are running mod_security.  Second, ask them to see if they can provide you with error log information with 500 errors.
    -greg
  • #5 / Feb 01, 2011 11:04pm
    Eric Snyder
    Yes, mod_security2 has been enabled.
    The error log was logging errors. Is this possibly a permission issue? My host made some permission changes that day.
    [Sun Jan 30 21:17:11 2011] [error] [client xx.xxx.xxx.xxx] File does not exist: /home/defaulte/public_html/eeadmin/sys_cpanel, referer: http://removed domain name.com/eeadmin/index.php?S=fe5dcf55bb63d064d50c323a329b6fcc00522d28&D=cp&C=design&M=update_template&tgpref=2
  • #6 / Feb 02, 2011 4:02pm
    Can you try to have them disable / tweak mod_security?
