Help - I've upgraded and now I'm unable to access the control panel
January 30, 2011 4:49am
Subscribe [4]
  • #1 / Jan 30, 2011 4:49am
    JulesWebb
    Upgrading from
    ExpressionEngine v2.1.0 - Build: 20100810 to v2.1.3
    I followed the instructions from: http://ellislab.com/expressionengine/user-guide/installation/update.html
    As the admin I can still see the front end of my site, but I can’t access the backend.  I just get a blank page.  I’m sure this has something to do with me setting up my sys folder above the web root.  When I originally installed EE I followed the instructions here: http://ellislab.com/expressionengine/user-guide/general/system_above_webroot.html
    Not sure what other information to give.
    thanks
    Jules
  • #2 / Jan 30, 2011 9:27am
    Neil Evans
    1. did you clear caches.
    2. in your index.php in the root of your site - where is the variable $system_path = pointing to? about line 26?
    3. when you used the instructions to setup above web root - have you replaced and checked your configuration in the admin.php file (opr whatever you called it?) do you perhaps need to re-create this file as part of the upgrade process?
  • #3 / Jan 30, 2011 6:00pm
    JulesWebb
    I thought I cleared the caches, but when I read your question I immediately questioned whether I did or not so now I don’t feel confident saying I did. ugh!
    The variable $system_path =  in the root of the site’s index file points to the system folder.  It is the same as it was before I tried the upgrade (I double checked against the bkup files I downloaded)
    The admin.php file I created looks the same as well.  To be sure I renamed the files on the server (index and admin) and uploaded the copies from the site bkup I downloaded prior to doing the upgrade.
    Before I did the upgrade I downloaded an entire site bkup, should I just go ahead and do a restore and try again?
    Appreciate your guidence.  Since this is my first upgrade I’ve no doubt I goofed somewhere.  Just now sure if it’s worth troubleshooting or just redoing.
    Jules
  • #4 / Jan 30, 2011 11:22pm
    ECKwa
    Hey nevsie
    I went ahead and did a restore and then did another version update.  Everything went fine.  I have no idea what I did wrong on the first attempt, but what I did learn is DON’T do an update with it’s late at night and your focus might be OFF! LOL
    Thanks for responding to mp plea for help:-)
    Jules
  • #5 / Jan 31, 2011 4:01pm
    Glad to see you’re all set. Please post again as needed.
