Problems integrating roating banner
January 16, 2011 4:43pm
  • #1 / Jan 16, 2011 4:43pm
    welshartnow
    I copied the source code from this page http://www.sohtanaka.com/web-design/examples/image-rotator/ (which validates) directly into a new EE2 template without any alteration. And viewed the result in a browser.  Firebug is throwing two errors :
    syntax error
    [Break On This Error] <!DOCTYPE html PUBLIC “-//W3C//DTD XHT…/xhtml1/DTD/xhtml1-transitional.dtd”>
    jquery….min.js (line 1)
    $ is not defined
    [Break On This Error] $(document).ready(function() {
    I’m guessing that the code should pass through ee unaltered and should validate as does the original code but there seems to be a problem.  I would be most grateful on any help since I would like to use this nice control within my project -thanks
  • #2 / Jan 17, 2011 12:11am
    Cheif
    There are so many holes in your issue it just isn’t funny, least of all is you have supplied absolutely no code to show what YOU are doing.
    Start by supplying something other than limited error copy ‘n paste!
  • #3 / Jan 17, 2011 10:11am
    Hi, welshartnow.
    If you look at the source code for that example, you’ll see there isn’t a full path to the javascript. I’ll bet that’s what part of the issue is.
    We’d really need more information on what you’ve tried so far. This will probably end up being a CodeShare Corner issue.
