Hi All 😊
Is there a way that I can lock an entry from being able to be deleted?
I have a situation where I have 3 pages that have 3 separate entries from one channel on them using the entry_id=”” tag. The idea is that the customer will edit just those entries when wanting to edit those pages. The problem is, if they delete those 3 entries by accident i will have to go back and change the number of the entry_id on the template.
I can’t just lock their user group from deleting entries because there are loads of other channels on the site that they need to be able to delete entries from - I just want to somehow protect those 3 entries in the one channel. If it helps, they are the only entries from that channel.
Cheers, and thanks for any suggestions,
Anthony
