Query Module not working
December 14, 2010 10:38pm
  • #1 / Dec 14, 2010 10:38pm
    SwitchDev
    I have the same basic problem, only I am using 2.1.1. Not sure what I should do?
    [EDIT]
    Sorry thought there would be more there.
    I have the query module installed, but I get this error when I try and use it.
    Error
    The following tag cannot be processed:
    {exp:query}
    Please check that the ‘query’ module is installed and that ‘query’ is an available method of the module
  • #2 / Dec 15, 2010 2:35pm
    Brandon Jones
    Hi yankeyhotel,
    Can you go ahead and upgrade to 2.1.2 to ensure we’re working with a fresh set of files?
  • #3 / Dec 15, 2010 4:22pm
    SwitchDev
    I updated, but now I am getting an error.
    Your system folder path does not appear to be set correctly. Please open the following file and correct this: index.php
    And when I change it to the right address I get this error
    Fatal error: Cannot redeclare EE_Template::_parse_var_single() in /.../.../..._system/expressionengine/libraries/Template.php on line 4136
    (... is replacing real address)
    My system folder is outside of the web root, and it is pointed at the correct location. My admin section is still working fine though?
  • #4 / Dec 15, 2010 6:27pm
    Brandon Jones
    Hi yankeyhotel,
    Can you try completely deleting the system/expressionengine/libraries directory and re-uploading it from the 2.1.2 package? It sounds like you might still have some old files up there.
  • #5 / Dec 15, 2010 6:49pm
    SwitchDev
    got it figured out thank you
  • #6 / Dec 15, 2010 8:03pm
    Brandon Jones
    Excellent, yankeyhotel! Going ahead and closing but don’t hesitate with any further questions.
