[OPEN] Query-module / SQL question
December 09, 2010 9:44am
  • #1 / Dec 09, 2010 9:44am
    Digitaal Dier
    Hi guys,
    I’ve implemented an alphabetical listing according to one of the methods in the Wiki, but apparently there’s also entries that start with a number. I thought retooling the query would be a walk in the park, but I can’t seem to get it to work, on account of being a total SQL-noob.
    My code is:
    {exp:query sql="SELECT title, entry_id, url_title AS urlt FROM exp_channel_titles WHERE channel_id = '4' AND title LIKE '[0-9]%' ORDER BY title ASC"}
                                    <li><a href="/dev.php/artists/detail/{urlt}">{title}</a></li>
                                    {/exp:query}
    I’ve tried hardcoding numbers into the LIKE-statement which works, so I probably just don’t have the right syntax for this.. Any thoughts?
  • #2 / Dec 09, 2010 2:07pm
    James Smith
    I’m no expert either but instead of LIKE ‘[0-9]%’, try
    REGEXP '^[0-9]'
  • #3 / Dec 09, 2010 5:12pm
    michaelroling
    REGEXP is the best way as mentioned above.  The only other way I can think of would be to substring the title and then perform a numeric comparison.  This will cause MySQL to cast the string as an integer.
    AND (substr(title,1,1) >=0 AND substr(title,1,1) <=9)
    or you could do
    AND substr(title,1,1) BETWEEN 0 and 9
