Pagination links - "First" link without trailing slash
December 01, 2010 3:04pm
Subscribe [4]
  • #1 / Dec 01, 2010 3:04pm
    Steve Garcia
    Currently on EE 1.7.0 and have the pagination links at the bottom of a search results page. When there are more than five pages, the “first” and “last” links appear. The arrows, numbers and “last” links work fine, however the “first” link doesn’t add a trailing slash at the end which goes to a 404 page when clicked.
    Couldn’t find where these link settings could be adjusted. Here’s my code:
    {if paginate}
        <div class='pagination_links'>
          {paginate}
        </div>
    Pretty straightforward. Any ideas?
    fyi - the site is still in development (launching soon) so if you need to see the page, PM me and I can send the url.
  • #2 / Dec 02, 2010 9:50am
    What else is in your search results page?
  • #3 / Dec 02, 2010 9:53am
    Steve Garcia
    Sorry, should have included it:
    {exp:search:search_results}
          <tr>
            <td class='part'>{title}</td>
            <td class='mfg'>{parts_manufacturer}</td>
            <td class='desc'>{parts_description}</td>
            <td class='family'>{parts_associated_series limit="3" backspace="2"}<a href="#" title="{title}">{title}</a>, {/parts_associated_series}</td>
            <td class='quote center_text'>
              <label class='none'>{title}</label>
              <input id='{title}' name='{title}' type='checkbox' />
            </td>
          </tr>
        {/exp:search:search_results}
  • #4 / Dec 03, 2010 2:28am
    SGarcia,
    Are you using a htaccess to remove your index.php?
    Can you test with that disabled and index.php back in place in your General Configuration
  • #5 / Dec 03, 2010 9:32am
    Steve Garcia
    That looks to be the cause. We’re using Leevi’s htaccess generator which has a section in the file that’s supposed to add a trailing slash to everything that doesn’t have an extensions so it should be adding the trailing slash. Will need to look into it further.
    Thanks for your help
  • #6 / Dec 03, 2010 9:42am
    Steve Garcia
    I tried using my custom htaccess file and that seems to be working. For those who are having the same problem, here’s my rewrite code.
    <IfModule mod_rewrite.c>
    RewriteEngine On
    RewriteBase /
    RewriteRule ^(.*)$ /index.php?$1 [L]
    </IfModule>
  • #7 / Dec 03, 2010 9:48am
    Thanks for sharing your solution with us. Please post again in case there’s anything else.
