v.2.0 and Changing default number of links displayed
November 12, 2010 12:51am
  • #1 / Nov 12, 2010 12:51am
    Jacobmiso
    I’ve seen this done but haven’t been able to invent a way to do it:
    By default, the basic paginate function displays between 3 and 5 live links along with the other info, Like this. It appears to depend on available width, ie - if it displays “last” etc.
    Page 1 of 48 pages 1 2 3 >  Last ยป
    I need to display about 10 (and also remove “next” last” etc text if possible
    It would essentially display as this:
    < 1 2 3 4 5 6 7 8 9 10 >
    I hope it’s easy to do, any help would be appreciated.
    btw, the code I’m using is the basic sample below taken directly from the user guide
    **Please note that this weblog sample is from 1x of course - however paginate in my 2.0 installs seems to work exactly the same -
    Im trying to setup for both
    {exp:weblog:entries weblog="latestnews" orderby="date" sort="desc" limit="1" paginate="bottom"}
    <h2>{title}</h2>
    <p>{summary}<br />
    {content}<br />
    {paginate}</p>
    <p>Page {current_page} of {total_pages} pages {pagination_links}<br />
    {/paginate}<br />
    {/exp:weblog:entries}
    [Mod Edit: Moved to the CodeShare Corner forum]
  • #2 / Nov 12, 2010 9:51am
    Please take a look at .../system/codeigniter/system/libraries/Pagination.php. You can specify there how many links you want EE to create.
  • #3 / Nov 13, 2010 5:12am
    Jacobmiso
    Thanks for the tip. Was able to customize how many links display and some interesting stuff.
    The var $num_links stopped me ultimately though, as it applies ‘symmetrically to before And after the current page. Since I want to display this:
    <12345678910> , if page 2 is selected, or 10 for example, the whole block moves.
  • #4 / Nov 14, 2010 1:31pm
    Greg Salt
    Hi Jacobmiso,
    I’ll move this thread to the CodeShare Corner since it’s more appropriate there but you might check on Devot://ee to see if there is an addon that will do what you need.
    Cheers
    Greg
