Importing EE Forum Data, something's wrong...
November 01, 2010 3:01pm
  • #1 / Nov 01, 2010 3:01pm
    FlashBoyz
    Hey guys, so I had EE 1.6.7 forums on a server that has since crashed. We were able to recover the mysql db. I’ve created a new forum in EE2, installed forum module, then imported the data for the forums through phpmyadmin(copied and pasted the “Dumping data for table…” into “SQL” tab in phpmyadmin)
    I went to the new forum and it looks like the forums imported fine but when I click on a forum, it shows no topics. New topics that are posted display fine. But none of the old topics are showing up. Any ideas would help, thanks!
    note: Old EE install was just a forum. New install has MSM
  • #2 / Nov 02, 2010 4:31am
    FlashBoyz,
    What version forum did you have installed on EE1.6.7 and now what version do you have installed on EE2.
    Your issue here looks like a version difference. There are likely differences in the db structure
  • #3 / Nov 02, 2010 6:27pm
    FlashBoyz
    The first/old forum was 2.1.1. We’re currently using 3.1.0
  • #4 / Nov 03, 2010 12:05pm
    Hi, FlashBoyz - there are major differences between Forum 2 and Forum 3; you can’t just copy the database tables over, you need to actually run the forum updater to make those changes.
    I would recommend rolling back and going through the upgrade procedure again, including visiting the Module’s control panel to initiate the database changes.
  • #5 / Nov 03, 2010 1:23pm
    FlashBoyz
    Ok, so just so I’m clear:
    1. Downgrade to 2.1.1 (I’m guessing using the upgrade instructions in the User Guide)
    2. Copy the forum tables over
    3. Then upgrade to 3.1.0
  • #6 / Nov 03, 2010 3:52pm
    Hi, FlashBoyz - not quite, your EE Discussion Forum module 2 is compatible with the EE 1 database.  You need to upgrade it from the EE 1 database to tohe EE 2 database.  That means upgrading it with your 1.6.7 install.
    You can’t copy EE 1 database tables into the EE 2 database.  There were too many database changes for that to work.
  • #7 / Nov 04, 2010 1:11pm
    FlashBoyz
    ahhhh ok. I’ll give that a whirl.
  • #8 / Nov 05, 2010 4:12am
    Let us know how you get on. Any problems we will be here
