Still awaiting to hear back on this one. Thanks again for your patience.
October 30, 2010 2:56pm
Subscribe [8]#16 / Nov 05, 2010 4:10am
#17 / Nov 05, 2010 1:36pm
No problem… I look forward to getting some final info. =)
#18 / Nov 06, 2010 3:54pm
Thank you. We’ll update this thread as soon as we can.
Cheers
Greg
#19 / May 17, 2011 10:00am
hi. Im new to EE2, though have made a few sites with EE1.6. Im having the weirdest problem with getting pagination to work in EE2, similar to this. The pagination just won’t show up, and though I thought it might be because there were only a couple of test entries, even when I used the conditional, still nothing showed.
Im also getting the div that holds the pagination appearing after each entry, not just at the bottom. my code is:
or just:
What am I doing wrong? I know Im using snippet to make the preview, but i don’t think that’s making any difference.
#20 / May 17, 2011 11:51am
Hi boshell—
Try adding enough entries in this channel so that your tag’s limit is less than the number of entries. In short, have enough entries so that pagination is necessary. Pagination doesn’t appear unless it’s necessary. 😉
Kevin
#21 / May 17, 2011 12:11pm
Yep, I go that now! It isn’t like that in EE1.6, so it took a bit of discovery, but with further testing, I’ve realised that. Thanks so much for the quick response, though, it gives me a lot of confidence in your support system. I’m really enjoying getting into EE2!
#22 / May 17, 2011 2:38pm
Glad Kevin cleared that up. Thanks boshell!
