So Wordpress is installed on the root.
example.com/
Expression engine 1.6.8 is on a child directory
example.com/ee/
I’ve tried adding the following to no avail:
RewriteCond %{REQUEST_URI} !^ee/
Any help would be appreciated
October 25, 2010 2:11am
Subscribe [3]#1 / Oct 25, 2010 2:11am
example.com/
example.com/ee/
#2 / Oct 25, 2010 8:56am
Ignoring .htaccess for the moment, does http://example.com/ee work as expected?
#3 / Oct 25, 2010 1:59pm
Nope. So I’ve moved wordpress off the root so that I now have example.com/ee/ and example.com/wp/ It is not the ideal solution however.
Initially Expression Engine had been at the root. I moved it to a child directory, and was able to have everything work except the index page:
so example.com/ee/section/ worked, but example.com/ee/ was a blank screen. Leaving the index.php file on the root directory however would work. in that case I would be able to see the homepage at example.com/ and sectionpages at example.com/ee/section. example.com/ee/ would still be blank.
I moved everything as suggested by this post:http://ellislab.com/forums/viewthread/171254/
I know this is convoluted. Any ideas?
The site is:
youngcubrecords.com
#4 / Oct 25, 2010 5:29pm
Can you remove .htaccess entirely from your setup? This is almost certainly a rewrite issue.
#5 / Oct 25, 2010 5:31pm
Which Setup?
root?
ee/
or
wp/
#6 / Oct 25, 2010 5:33pm
Yes, all of them, as they’re cascading down.
