Hi EE’rs. I’m getting pretty comfortable with EE now but the one part of the puzzle that i haven’t yet been able to wrap my head around is sitemaps. Are there some best or at least common practices when it comes to creating a sitemap in EE?
October 22, 2010 10:38am
Subscribe [3]#1 / Oct 22, 2010 10:38am
#2 / Oct 22, 2010 10:46am
I haven’t worked with it, but there seems to be a module for that purpose. Might be worth checking out.
#3 / Oct 22, 2010 1:34pm
I often just create a template that lists all required entries - example http://www.blue-dreamer.co.uk/sitemap/
You could also use a XML template as well if you wanted data like chnage frequencies etc
#4 / Oct 24, 2010 1:37am
Just throwing this out there, but if you happen to be using Structure (buildwithstructure.com) for your site navigation, it has a tag for dynamically displaying the sitemap automagically =)
#5 / Oct 24, 2010 7:40pm
Bluedreamer, I think I’ll probably approach it the way you have - seems like a straight forward way to handle it. THanks for the advice. I’m not using Structure currently (though I’ve been debating giving it a try for a future project) so that little tidbit I’ll have to try out when I do.
Thanks all.
Jean
