setting sql_mode per session basis
October 11, 2010 2:54am
  • #1 / Oct 11, 2010 2:54am
    jackmcpickle
    Hi
    Mt host is running php5.2 / sql 5 but currently using the following mode:
    sql_mode STRICT_TRANS_TABLES,NO_AUTO_CREATE_USER,NO_ENGINE_SUBSTITUTION
    I have access to phpmyAdmin but not enough privilages to change the mode. I know you can change the mode on a per session basis.
    Is it possible to set the sql_mode in the db.mysql.php??
    Found these few articles on changing for wordpress but cant figure out what I need to do for EE. Really going out on a limb here and just trying to get something working.
    http://rpbouman.blogspot.com/2007/04/so-wordpress-does-not-like-mysql-sql.html
    http://rpbouman.blogspot.com/2007/04/guess-whatwordpress-does-not-like.html
    function db_connect($select_db = TRUE)
            $this->conn_id = ($this->conntype == 0) ?
              @mysql_connect ($this->hostname, $this->username, $this->password):
              @mysql_pconnect($this->hostname, $this->username, $this->password);
            // fix sql_mode
                    mysql_query("SET SESSION SQL_MODE := ''",$this->database);
            // end fix sql_mode
    Thanks.
  • #2 / Oct 11, 2010 3:40pm
    I honestly don’t know. It would certainly require some hacking of EE core files, which we’re unable to support. Perhaps you could upgrade to EE 2.1? It no longer has the “no strict mode” requirement.
