Hello. I recently moved a site to a new server. I imported the database and everything appeared to be fine. I needed to change some weblog entries to a new weblog/category scheme, so I used phpMyAdmin to change the weblog_id and category_id of several entries (or so I thought).
One entry in particular is giving me problems in the wake of this operation (I suspect that a lot of the entries will ultimately give me problems, but this is the first one I’ve run up against).
The entry was originally in a weblog called “news_general”. I moved it to a new weblog called “news” through a mySQL query (in phpMyAdmin). With a subsequent mySQL query (again, in phpMyAdmin), I tried to change the category id.
In the EE control panel, when I search for entries in the news_general weblog, this particular entry is returned. When I click through to the entry and check the weblog on the Options tab, the weblog is listed as “news” and it has no categories assigned. When I try to assign a category and update the entry, I get a blank screen (except for the control panel header and footer). And nothing I do seems to enable me to change the weblog (I tried moving it to another weblog temporarily so I could move it back into “news” but whenever I update, I just get that blank screen).
When I look in phpMyAdmin, it lists the entry as being in the “news” weblog.
Any thoughts on why this might be happening?
Frank
