Stand Alone Entry - Reloads a blank page !?
September 06, 2010 8:30am
Subscribe [4]
  • #1 / Sep 06, 2010 8:30am
    Triad
    We’ve got an issue on a site thats built on 1.6.8.
    We have a members database, where users can post news to the site via the front end using exp:weblog:entry_form tag (after they’ve logged in)
    At present, when we click submit, the page reloads itself, same URL, but totally blank page, no HTML source either.
    We then tried logging in as the Super User to check if its permissions, and the same result.
    Next we tried stripping back the page to bare basics, only trying to add a ‘title’, but its the same.
    This is the code of the template page…
    {exp:weblog:entry_form weblog="news" }
    Title
    <input type="text" name="title" id="title" size="50" maxlength="100" /></p>
    {/exp:weblog:entry_form}
    Any data does not get added to the Weblog. We’ve also tried a different & new weblog to make sure its not that.
    We’ve also disabled any extensions/modules (not using ‘Strucutre’ as we’ve read it can cause problems)
    Does anyone know what could be causing this?!
    Many thanks,
    Matt
  • #2 / Sep 07, 2010 3:17am
    Matt,
    in this particular case rather than stripping back the form can you try it with the example form in our docs please. Be sure to set a correct return url
    What are the other extensions you are using?
  • #3 / Sep 07, 2010 4:43am
    Triad
    Matt,
    Thanks John
    We’ve tried it with the example form, and all the same - just get a blank page on reload. The URL doesn’t actually change, nor the entry goes into the DB.
    Extensions we are installed are..
    FieldFrame (v.1.4.2)
    LG TinyMCE (v.1.3.3)
    LG Member Form Customiser (v.1.1.0)
    LG SAEF File Upload (v.1.0.0)
    User (v.2.0.3)
    jQuery for the Control Panel (v.1.1.1)
    Edit Menu (v.1.0.2)
  • #4 / Sep 07, 2010 11:54am
    Triad, try temporarily turning off all of your extensions by clicking the big green button labeled Disable Extensions.
    Does disabling them help?
  • #5 / Sep 07, 2010 12:33pm
    Triad
    Hi Sue
    Thanks - we have tried this already, and the same thing happens. feel we’ve done everything, and no idea what’s causing it :(
  • #6 / Sep 07, 2010 5:45pm
    Is there a particular reason for using 1.6.8? Otherwise I’d suggest an upgrade to the latest build, if only to be on the same page in terms of code; also helps to rule out file corruption issues, of course.
