The problem is I didn’t change any of the other files, except changing the url inside config.php.
I only added those 2 files.
If I changed my code to the following, there isn’t any error.
class Test extends Controller {
function Test()
parent::Controller();
function index()
$CI =& get_instance();
$CI->load->model('category_model');
$CI->category_model->get(1);
I did a print_r($CI) inside the Loader library’s model function, category_model is there.
I can even call the model via $CI->category_model and no error.
function model($model, $name = '', $db_conn = FALSE)
if (is_array($model))
foreach($model as $babe)
$this->model($babe);
return;
if ($model == '')
return;
// Is the model in a sub-folder? If so, parse out the filename and path.
if (strpos($model, '/') === FALSE)
$path = '';
else
$x = explode('/', $model);
$model = end($x);
unset($x[count($x)-1]);
$path = implode('/', $x).'/';
if ($name == '')
$name = $model;
if (in_array($name, $this->_ci_models, TRUE))
return;
if (isset($CI->$name))
show_error('The model name you are loading is the name of a resource that is already being used: '.$name);
$model = strtolower($model);
if ( ! file_exists(APPPATH.'models/'.$path.$model.EXT))
show_error('Unable to locate the model you have specified: '.$model);
if ($db_conn !== FALSE AND ! class_exists('CI_DB'))
if ($db_conn === TRUE)
$db_conn = '';
$CI->load->database($db_conn, FALSE, TRUE);
if ( ! class_exists('Model'))
load_class('Model', FALSE);
require_once(APPPATH.'models/'.$path.$model.EXT);
$model = ucfirst($model);
$CI->$name = new $model();
$CI->$name->_assign_libraries();
$this->_ci_models[] = $name;
// tracing
print_r($CI);
I am suspecting that the $CI is not referenced properly.
Is $this same as $CI =& get_instance() ?
Could it be a php.ini setting that is affecting this?
