Login problems after multiple sites enabled - fresh 2.1 install
July 23, 2010 1:08pm
  • #1 / Jul 23, 2010 1:08pm
    John Geddes
    I just did a fresh 2.1 install (using code I downloaded yesterday from your site), and it worked great.  I could log in and everything was fine.  I then copied over the MSM php files and then when I went into the admin to enable multiple sites, and now I can’t log in any more.
    I get:
    An Error Was Encountered
    Unable to load the requested file: account/login.php
    I’ve since deleted the MSM php files and have set
    $config['multiple_sites_enabled'] = "n";
    but I still can’t log in, and I get the same error as above.
    I’m stuck…
  • #2 / Jul 23, 2010 5:23pm
    Brandon Jones
    John, first I’d recommend:
    1. Overwriting /index.php on your site with /index.php from the download package (edit it to set your system folder name appropriately)
    2. Overwrite /system/index.php on your site with /system/index.php from the download package (do not edit this)
    If there’s still no change, try adding this to your /system/expressionengine/config/config.php file:
    $config['theme_folder_path'] = '/themes/';
    Keep us posted.
  • #3 / Jul 23, 2010 5:59pm
    John Geddes
    OK, it was the third change that did it.  Almost like when I turned MSM on, that line disappeared, maybe?
    So, adding the following to the config.php fixed it:
    Thanks for the help!!!!
  • #4 / Jul 23, 2010 7:10pm
    Brandon Jones
    John, changes to the host configuration might necessitate that line, though it generally isn’t required. Glad that worked for you - don’t hesitate with further questions.
