multi language site - membership utf-8 questions
July 15, 2010 3:23pm
  • #1 / Jul 15, 2010 3:23pm
    phoebe_reed
    I"m creating a site in En, Fr and Sp.  I have found a lot of help on these forums, and things are going well.
    I am trying to convert all (?) the EE databases to UTF-8 char set (from the latin setting).
    I am doing this because I believe that I need member data (member names, addresses, etc.), and Blog/Channel data to both be written to the Database in utf, in case there are french or spanish characters.
    I am not having any luck changing the fields in the actual tables in the ee db, and I am wondering if maybe this is overkill.  Is this necessary even?
    My needs are only around membership and blogs/news/events.  So I just want to make sure the db is capable of saving and returning french and spanish language effectively.
    Thanks for any help.
    Phoebe
  • #2 / Jul 15, 2010 3:31pm
    No, you probably don’t have to convert your database. Spanish has a few accents and the ñ, French the same plus ç. All characters are part of ISO-8859-1 / 1-8859-15 as well. I still recommend to use UTF-8 for your site, but there’s probably no need to mess with the db collation.
  • #3 / Jul 15, 2010 4:19pm
    phoebe_reed
    So, if someone puts in a name that has a french accent in it, as their screenname, or whatever, the database will have no issues storing that in the member database, whcih looks like a latin char set still, and then spitting it back out with the proper accent?
    I’m concerned that if the DB tables are not utf-8, then will normal accents and such get messed up in the database?  I’m confused, I think, about how the DB stores a french character. Have to read up on it.
    thanks,
    Phoebe
  • #4 / Jul 15, 2010 4:34pm
    Yes, that’s right.
    No, I don’t think that’s reason for concern.
    It doesn’t really matter as long as it’s properly translated. Luckily both Latin-1 and Unicode contain the needed subset of characters.
  • #5 / Jul 15, 2010 4:37pm
    phoebe_reed
    Gotcha.
    Thanks!  That makes things much easier.  I just put in the language packs for the CP, which work awesomely.
    -phoebe
  • #6 / Jul 15, 2010 4:41pm
    Sounds good. I am going to make this one as “Resolved” for now, but if you’re having any issues in that regard, please start a new thread, we’re happy to help 😊
