problem while restoring/installing EE
July 13, 2010 10:53pm
  • #1 / Jul 13, 2010 10:53pm
    creativeworks
    hi,
    I’m trying to install a EE site that is already installed on a live site, i have to change a few things,  i was provided with the site files and the database dump. The problem is that before setting up the database on my local server and edit the configuration file I just get a blank page, and the backend shows me the login but it doesn’t allows me to log in, even if i do it with the correct user and pass..
    obviously I0m doing something wrong here, can someone please give instructions on how to do this..? is there any specific process to install/reinstall an EE site..?
    thanks.
  • #2 / Jul 14, 2010 3:48am
    creativeworks,
    Welcome to the forums 😊
    So just to confirm. You are trying to get this up and running locally first?
    What happens? Do you get an error or does the page just refresh?
    In your system/config.php can you try and add the following
    $config['cookie_domain'] = '';
  • #3 / Jul 14, 2010 2:19pm
    creativeworks
    John,
    thanks a lot for your help, fortunately i was able to solve it, the problem was not on my configuration files exactly, it was the database, i thought i should replace all the links from the live site on the .sql file before updating my local database and so i replace them all, that was the problem, there is no necessity to do that.
    anyway, thanks a lot for the help. 😊
    creativeworks
  • #4 / Jul 14, 2010 3:40pm
    Glad to see you’re all set. Please post again as needed.
