group channel entries by custom field + generate headers
June 17, 2010 12:08am
  • #1 / Jun 17, 2010 12:08am
    Michael Rog
    The channel module makes it easy to SORT by a custom field, but I need to GROUP entries by a custom field and then generate headers (similar {date_header}) to appear before each group.
    Is there any way to twist native features to do this, or do I need to resort to custom SQL?
  • #2 / Jun 17, 2010 1:36am
    ender
    You can use the string plugin to do this.
    I posted a code sample for doing this within the rows of a FF Matrix custom field here but the strategy will work just as well to do something similar with a set of entries inside a weblog:entries tag.
  • #3 / Jun 17, 2010 11:58am
    Michael Rog
    Indeed, that is exactly the strategy I need!
    (http://ellislab.com/forums/viewthread/157893/)
    Your String Plugin looks like a great addon. Curiously, though, is there any advantage to using the plugin over straight PHP conditionals (parsed on output)?
  • #4 / Jun 17, 2010 12:27pm
    ender
    a couple minor advantages in some situations based on EE’s strange parse order (where output PHP would be executed from top to bottom after the EE parser was done with the template), but no if you are comfortable with PHP you can easily use that in this instance.
  • #5 / Jul 29, 2015 3:41pm
    tacuster
    How might the string plugin be used without a Matrix field to perform the same task? I simply have a channel of stores that I’d like to group by state. State is one of the custom fields in the channel. I’d like to use that same state field as header for each group of stores.
    IDAHO
    Store #1
    Address
    Phone
    Store #33
    Address
    Phone
    CALIFORNIA
    Store #9
    Address
    Phone
    Store #56
    Address
    Phone
    etc…
