how to use header and footer in codeigniter
May 31, 2010 8:44am
Subscribe [4]
  • #1 / May 31, 2010 8:44am
    physicfor
    i have site with a dynamic header with diffrent categories
    which changed from page to page i need to include the header in every page
    i create header.php in the view folder but every time
    i have to pass the category array to the header view in every page
    i read the manual and i search this forum there is a similar post with no answer
    please if any one can help
    and here is the very similar post
    http://ellislab.com/forums/viewthread/96974/P0/
  • #2 / May 31, 2010 9:08am
    kkith
    I’m not sure what your question is.
    Hm, the first response by Rey Philip Regis in your link with the similar post has a great example.  Are you asking if there is a way for CI to create a view that automatically includes the category?  If so, then no CI doesn’t do that.  Nor does any other framework I know of.
  • #3 / May 31, 2010 9:17am
    physicfor
    so i think the beast way is to create parent controler with header and footer methods then extend this controler in other controlers
    am i wright !!!!!
  • #4 / May 31, 2010 7:23pm
    vitoco
    i think this may help you to get a different perspective
    http://ellislab.com/forums/viewthread/156134/
    ...maybe a wiki and a working example will help
    Saludos
  • #5 / Jun 01, 2010 8:09am
    physicfor
    Saludos
    thank you
    and for pepole who will read this post i solve my problem with the following
    first i extend the controler class by
    go to libarry in the aplication folder and create MY_Controller.php
    this file contain
    class Application extends Controller
        var $controllers; // These all track root folders for views, models, controllers; specified in Auth config
        var $models;
        var $views;
        function header()
        $this->load->view('headerfooter/header');
        function footer()
        $this->load->view('headerfooter/footer');
        function Application()
            parent::Controller();
    then in other controler in my aplication i use
    class Test extends  Application {
        //this is the initilization for the class
        function Test()
           //parent::Myclass();
        function index()
            $this->header();
            $this->load->view('test');
            $this->footer();
    thans every one for helping
  • #6 / Jun 01, 2010 12:22pm
    Piter
    Hi, I use is Layouts:
    application/librares/layout.php
    <?php
    if (!defined('BASEPATH')) exit('No direct script access allowed');
    class Layout
        var $obj;
        var $layout;
        function __construct($layout = "layouts/page")
            $this->obj =& get_instance();
            $this->layout = $layout;
        function setLayout($layout)
        function view($view, $data=null, $return=false)
            $loadedData = array();
            $loadedData['content_for_layout'] = $this->obj->load->view($view,$data,true);
            if($return)
                $output = $this->obj->load->view($this->layout, $loadedData, true);
                return $output;
            else
                $this->obj->load->view($this->layout, $loadedData, false);
    $this->load->library('layout');
    $this->layout->view('myfile', $data);
    Layouts page
    <html>
    <header></header>
    <body>
    <div id="header">
    </div>
    <div id="content">
    <?php echo $content_for_layout; ?>
    <div>
    <div="footer">
    </div>
    </body>
    </html>
