Solution For Redirection After Registration
March 23, 2010 2:13am
Subscribe [6]
  • #1 / Mar 23, 2010 2:13am
    Deep Arora
    I was struggling to find a solution for redirecting users after registration. Read few threads, found a $99 solospace plugin too..ouch!
    Then finally made a small change in a core file and bingo!
    Not sure if someone has already done this, but if not, you may find it useful.
    Making this small change in one of the core file allows you to redirect user to immediately after registration to any page you desire.
    Open the file “system\expressionengine\modules\member\mod.member_register.php
    Search for this line:
    'content'    => $this->EE->lang->line('mbr_registration_completed')."\n\n".$message,
    Just below this line, you will see a line as:
    'redirect'    => '',
    Change it to this:
    'redirect'    => $this->EE->db->escape_str($_POST['RET']),
    Now, in your EE registration form template,
    <form id='register_member_form' method="post" action="http://yoururl.com/anytemplate"  >
    <input type="hidden" name="XID" value="{XID_HASH}" />
    <input type="hidden" name="ACT" value="7" />
    <input type="hidden" name="RET" value="http://yoururl.com/anytemplate" />
    <input type="hidden" name="FROM" value="" />
    In the RET field, give any URL where you want to redirect the user to.
    Hope this helps.
    Thanks.
  • #2 / Mar 23, 2010 11:15pm
    lebisol
    Cool, it would be nice if it was dynamic grabbing the last URL prior to register page and then redirect back.
    Thanks for sharing!
  • #3 / Mar 23, 2010 11:28pm
    Deep Arora
    I guess that is easy with something like this:
    'redirect'    => $_SERVER['HTTP_REFERER'],
    though I didn’t try it, but this should work..
  • #4 / Mar 24, 2010 1:49am
    lebisol
    😊 yeah I just realized that it can be a php EE template.
    Nice.
  • #5 / May 18, 2010 8:13am
    redfred
    How do you get swap this bit of code on the registration template, as it isn’t actually on the template when you go to edit:
    <form id='register_member_form' method="post" action="http://www.mysite.com/index.php"  >
    <div class='hiddenFields'>
    <input type="hidden" name="XID" value="70675c296dc8e450a12c14e92ab4d580496c9149" />
    <input type="hidden" name="RET" value="http://www.mysite.com/index.php" />
    <input type="hidden" name="site_id" value="1" />
  • #6 / Jun 27, 2010 8:37pm
    koala kid
    Thanks for the tip, I’ve just been struggling with the same issue myself.
    For anyone who has had to enable “Force URL Query Strings” via the control panel you have to remove the string clearing function, not as secure but still works:
    'redirect'  => $_POST['RET'],
    I’m not sure why this is not enabled by default though as they provide a RET parameter to the form, why leave it empty in the registration script? Bug?
  • #7 / Jun 29, 2010 9:09pm
    lebisol
    For those looking to take it step further consider this article and extension for extending member templates.
  • #8 / Jul 08, 2010 4:07pm
    Elemento, Inc.
    i replaced it with:
    tested and working. thanks for pointing me to the direction.  that $99 plugin was tempting though.
    I used the form in this template: http://expressionengine.com/wiki/Standalone_Registration_Form/
    thanks again!
