Help: Using “Related Entries” multiple times causes error
March 06, 2010 11:59am
  • #1 / Mar 06, 2010 11:59am
    Luc Latulippe
    Am I to understand it’s not possible to use Related Entries more than a single time in a weblog entry? The code below ends up yielding a string of gobbledygook, but when I use only a single instance of Related Entry, everything works as expected.
    {exp:weblog:entries weblog="weblogname"}
        {title}
        {body}
            {related_entries id="customfield_1"}{fieldname}{/related_entries}
            {related_entries id="customfield_2"}{fieldname}{/related_entries}
            {related_entries id="customfield_3"}{fieldname}{/related_entries}
    {/exp}
    In this case, I happen to also be using Conditional Global Variables, but with or without, the results are the same. Basically it outputs this:
    {REL[customfield_1]LLkhQT49REL}
    {REL[customfield_2]cB40XeroREL}
    {REL[customfield_3]XdTkINfzREL}
    As I understand it, Playa or some other plugin or extension would potentially resolve this, but before I purchase anything I was wondering if there was an existing solution. Thanks!
  • #2 / Mar 06, 2010 12:37pm
    Luc Latulippe
    Happily, Mark Huot’s Multi-Relation extension did the trick for now: http://ellislab.com/forums/viewthread/39595/
