If One Comment, Show "Comment" Title. If Two Comments, Show "Comments" Title.
December 08, 2009 2:34pm
  • #1 / Dec 08, 2009 2:34pm
    Big Skillet
    I need to setup an {if} statement that will show “1 Comment” when there is only one comment.  If there are multiple comments, the title should have an “S” on the end with the title being “2 Comments”.
    Is that possible?  Not sure how to do it…
  • #2 / Dec 08, 2009 4:10pm
    Bob Sutton
    Have you tried something like this between your {exp:comment:entries} tags?
    <h5>{count} COMMENT{if count >1}S{/if}</h5>
    You could probably also test for count!= “0” and selectively display the comment counter or an alternate message like “Be the first to Comment about this Entry!”
  • #3 / Dec 08, 2009 4:39pm
    Big Skillet
    Thanks Bob!  That works great, but it also removes the “s” when there are no comments.  I need it to be “0 Comments” instead of “0 Comment”.  I tried modifying the if statement, but not luck…
  • #4 / Dec 08, 2009 4:43pm
    {count} comment{if count != 1}s{/if}
  • #5 / Dec 08, 2009 4:49pm
    Big Skillet
    Ahhh… I figured out why it wasn’t working.  I was trying to use “count”, but this case called for “comment_total”.
    Comment{if comment_total != 1}s{/if}
  • #6 / Dec 08, 2009 4:50pm
    Bob Sutton
    I don’t have time to run this in a live page that has comments, but it oughta work:
    <h5>{count} COMMENT{if count == 0 OR if count >1}S{/if}</h5>
  • #7 / Dec 08, 2009 4:51pm
    Big Skillet
    Thanks Bob & Ingmar… Problem solved.
  • #8 / Dec 08, 2009 4:57pm
    Bob Sutton
    You’re right. COUNT is the sequence where the Comment occurs in a Comment list for an entry. e.g. “This is Comment No. {count}.” My bad.
