Problem autoloading helpers..
November 15, 2009 1:59pm
  • #1 / Nov 15, 2009 1:59pm
    teamcoder
    Hello everyone,
    I am a newbie to PHP,well to coding in general but am picking it up pretty well, and thanks to some great informative sites out on the net things are going great, I have just one issue I cannot seem to resolve.
    I am using XAMMP and everything is working as planned and am able to code everything and it is all working well except I cannot seem to get the helpers to help, i am getting
    “Fatal error: Call to undefined function form_open() in C:\xampp\htdocs\codeigniter\system\application\views\newsletter.php on line 21”
    I have set up the autoloader to load the form_helper and the url_helper but it does not seem to be loading it, I have even tried loading it the control file as such
    This is my view file
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
    <html>
      <head>
        <title>News Letter</title>
        <meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
      </head>
      <body>
        <div id = "newsletter_form">
            <?php echo form_open('email/send');?>
            <?php
            $name_data = array(
                'name' => 'name',
                'id' => 'name',
                'value' => set_value('name')
            <label for="name">Name: </label><?php echo form_input($name_data); ?>
                <label for='name'>Email Address:</label>
                <input type='text' name='email' id-'email' value='<?php echo set_value('email');?>'>
            <?php echo form_submit('submit',"Submit");?>
            <?php echo form_close(); ?>
        </div>
      </body>
    </html>
    And here is my controller file
    <?php
    Class Email extends Controller
        function __construct()
            parent::Controller();
        function form()
            $this->load->helper('form');
        function index()
            $this->load->view('newsletter');
        function send()
            $this->load->library('email');
            $this->email->set_newline("\r\n");
            $this->email->from('*********.com', '*****');
            $this->email->to('**********.com');
            $this->email->subject('This is an email test');
            $this->email->message('Its working yippie');
            $path= $this->config->item('server_root');
            $file = $path . '/codeigniter/attachment/yourinfo.txt';
            $this->email->attach($file);
            if($this->email->send()){
                echo 'Your email was sent';
            else{
                show_error('$this->email->print_debugger()');
    If anyone has any thoughts as to how I can set it up to work, I am running it on WindowsXP, codeigniter is setup in my htdocs folder and as I said other apps that I have written have all worked out great but everytime I try to use the form_helper I have the same issues.
    PLEASE HELP ME!!!! :ahhh:
  • #2 / Nov 15, 2009 2:14pm
    jedd
    Hi teamcoder and welcome to the CI forums.
    Try moving your form loader into the autoload.php (application/config/) file, or at the very least load it in the same method of your controller that then calls the view.
    That is, move this line:
    - from out of your form() method and into your index() method.
    I’d suggest that your code will probably morph a fair bit, so for the moment stick it in autoload.  You can selectively load things like this if / when performance becomes relevant.
  • #3 / Nov 15, 2009 3:20pm
    teamcoder
    Thanks for the fast respond and the welcome,
    Well everything you had mentioned I had done or is already done, here is my autoloader file.
    <?php  if ( ! defined('BASEPATH')) exit('No direct script access allowed');
    | AUTO-LOADER
    | This file specifies which systems should be loaded by default.
    | In order to keep the framework as light-weight as possible only the
    | absolute minimal resources are loaded by default. For example,
    | the database is not connected to automatically since no assumption
    | is made regarding whether you intend to use it.  This file lets
    | you globally define which systems you would like loaded with every
    | request.
    | Instructions
    | These are the things you can load automatically:
    | 1. Libraries
    | 2. Helper files
    | 3. Plugins
    | 4. Custom config files
    | 5. Language files
    | 6. Models
    |  Auto-load Libraries
    | These are the classes located in the system/libraries folder
    | or in your system/application/libraries folder.
    | Prototype:
    |    $autoload['libraries'] = array('database', 'session', 'xmlrpc');
    $autoload['libraries'] = array('database');
    |  Auto-load Helper Files
    | Prototype:
    |    $autoload['helper'] = array('url', 'file');
    $autoload['helpers'] = array('url', 'form');
    |  Auto-load Plugins
    | Prototype:
    |    $autoload['plugin'] = array('captcha', 'js_calendar');
    $autoload['plugin'] = array();
    |  Auto-load Config files
    | Prototype:
    |    $autoload['config'] = array('config1', 'config2');
    | NOTE: This item is intended for use ONLY if you have created custom
    | config files.  Otherwise, leave it blank.
    $autoload['config'] = array();
    |  Auto-load Language files
    | Prototype:
    |    $autoload['language'] = array('lang1', 'lang2');
    | NOTE: Do not include the "_lang" part of your file.  For example
    | "codeigniter_lang.php" would be referenced as array('codeigniter');
    $autoload['language'] = array();
    |  Auto-load Models
    | Prototype:
    |    $autoload['model'] = array('model1', 'model2');
    $autoload['model'] = array();
    /* End of file autoload.php */
    /* Location: ./system/application/config/autoload.php */
    If any other possibilities please let me know, again thanks for the help.
  • #4 / Nov 15, 2009 7:10pm
    jedd
    Have you changed your controller / view code too?  If you have the form helper being autoloaded, you don’t need to load it in your controller.
    When posting a lump of code with an error like ‘at line xyz, this error happens’ - it’s polite to identify the line number in your code.  Line 21, by my count, for example, is not an error-producing line.
  • #5 / Nov 15, 2009 8:31pm
    wiredesignz
    Do you notice the problem you have if you compare your autoload script to this copy of the original.
    $autoload['helper'] = ...
  • #6 / Nov 15, 2009 9:25pm
    teamcoder
    I’m sorry lab,
    I did post the error and the line in my first post, sorry I didn’t repeat myself,but I have taken it out of the controller file and let it run from the autoloader, no luck then I tried it vice versa, still no luck, it just won’t build the form and spit’s out that error.
    SoI don’t know where to go from here, I have my codeigniter folder in my htdocs folder where it should be, it sends emails like it should, but it won’t build the form, and I had the same problem in another app I tried to put together.
    I’m stumped,anyone else have any ideas?
  • #7 / Nov 16, 2009 12:23am
    Aken
    Did you change your autoload key to ‘helper’ as wiredesignz suggested?
