Moblog entries do not post
September 17, 2009 2:55pm
Subscribe [5]
  • #1 / Sep 17, 2009 2:55pm
    karms
    I suspect this is “operator error”, but I’ve not come across an answer yet.  I just activated the Moblog module, and setup the appropriate preferences.  When I click “check moblog” from within the module, the response is “Moblog was successfully checked”, however the entries added count is 0.  Moblog says it is retrieving email on each check, but never adds an entry.  Any help appreciated.  I am running v1.6.7 Build: 20090211.
  • #2 / Sep 17, 2009 5:42pm
    You might want to upgrade to the latest build, if only to rule out corrupted files (and because it’s a recommended security update). I suppose you have created a new moblog, and filled out all the required preferences, including the weblog to post to?
  • #3 / Sep 17, 2009 6:00pm
    karms
    Thanks Ingmar - yes, all the required prefs are completed, and I’ve added the moblog: check tag to my index template.  It’s pretty vanilla really.
  • #4 / Sep 17, 2009 10:11pm
    karms
    Well, that didn’t go so well.  I followed the EE upgrade instructions located at http://expressionengine.com/docs/installation/update.html.  First problem I encountered was I could not login to the CP after the upgrade.  I reset my pswd and ultimately got in.  The next thing I see is that the MoBlog module is not listed in the Modules tab.  I also get an error when accessing the index.php template as I had the moblog: check tag listed within it.  So how do I get my moblog module back?
  • #5 / Sep 18, 2009 2:07am
    karms,
    On your server when you FTP in, does the folder system/modules/moblog exist?
  • #6 / Sep 18, 2009 8:41am
    karms
    Hi John - no, the moblog folder is not listed.  Stupid question, but is it part of MSM ?  I did have MSM installed.  I see the note on the install page that says “If the Discussion Forum Module or Multiple Site Manager is installed, it is necessary to update them immediately after completing the ExpressionEngine update.”  How is MSM to be updated?  Do I need to make a purchase?
  • #7 / Sep 18, 2009 4:45pm
    Hi, karms.
    Are you certain you upgraded the right install, or downloaded the full version instead of the Core version?
    The MSM files you download a second time if needed, but you don’t need to purchase them again.
    Does that help?
  • #8 / Sep 18, 2009 5:03pm
    karms
    You are correct - I downloaded the Core version as it was the only one listed at the https://secure.expressionengine.com/download.php site.  Where do I download the full release?  Or do I need to purchase the upgrade?
  • #9 / Sep 18, 2009 5:13pm
    Do you see a link that says Renew? Are you the person who installed EE? Did you purchase it over a year ago?
  • #10 / Sep 18, 2009 5:21pm
    karms
    Thanks Sue - answers below..
    Do you see a link that says Renew? No
    Are you the person who installed EE? Yes
    Did you purchase it over a year ago? No, March of 2009
  • #11 / Sep 18, 2009 5:28pm
    I’m seeing that you have a support credit, but not that you purchased it. You might want to contact .(JavaScript must be enabled to view this email address) and work with them on enabling you to download.
    ETA: The Support Credit grants you only access to technical support.  You will need to login with the account that purchased in order to download updates.
  • #12 / Sep 18, 2009 6:39pm
    jstrike
    thanks - got the proper credentials now and will do this right this time.
  • #13 / Sep 19, 2009 10:41am
    jstrike
    Ok - update successfully completed to 1.6.8 Build: 20090915.  Now i am back to the OP - I get the below response when I check moblog..
    Emails Retrieved: 2
    Entries Added: 0
    Attachments Uploaded: 0
    Pings Sent: 0
    I cleared the moblog prefix so all emails are retrieved.  I have the correct weblog set in the pref’s.  My other settings are as follows..
    Default Categories: None
    Default Field: None
    Default Status: None
    Default Author: me
    I also have the valid from email addresses set.
  • #14 / Sep 19, 2009 4:56pm
    Greg Aker
    jstrike:
    In your moblog configuration:
    Do you have a Subject Prefix set?
    Is Authorization Required in Email set to yes or no?
    Are you using the Valid ‘From’ Emails for Moblog feature?
  • #15 / Sep 20, 2009 9:37am
    jstrike
    Hello Greg - I have tried it with and without the subject prefix.  Same result for each.  Auth Required is set to No.  I also have tried it with and without valid ‘from’ emails - same results for each there too.
