I enabled error checking and get the following error:
Parse error: syntax error, unexpected $end in /homepages/xxxxxxxxxx/xxxxxxxxxxx/system/cp/cp.display.php on line 1386
Does anyone have any idea where I should begin to troubleshoot?
thanks,
/ff.
September 10, 2009 6:06pm
Subscribe [3]#1 / Sep 10, 2009 6:06pm
thanks,
/ff.
#2 / Sep 10, 2009 6:09pm
#3 / Sep 10, 2009 6:41pm
we have 1.6.8 installed.
#4 / Sep 11, 2009 2:01am
Francis,
You might want to re-upload your EE files, so to rule out file corruption.
Do not reinstall EE (do not run install.php), just re-upload your files.
Basically, the way you’d do with a build update.
Be sure to make & verify a db backup for piece of mind.
#5 / Sep 11, 2009 2:33am
Thanks John. That seems to have fixed it.
Appreciate the help.
/ff.
#6 / Sep 11, 2009 2:37am
Glad that worked for you. Feel free to start a new thread if you have any more questions.
