Help needed refactoring a long conditional (EE bug?)
August 15, 2009 12:55pm
  • #1 / Aug 15, 2009 12:55pm
    mikec964
    I’m trying to add a fairly complex conditional to my template, and the results are unpredictable. As best I can tell, if the conditional is too long, the entire {exp:weblog:entries} tag that contains it fails to execute.
    I pasted the conditional here, and added line feeds for readability. (It’s a shame I can’t have those line feeds in my actual source code.)
    As soon as I added the code between the >>> and <<<, the conditional stopped working.
    If there’s a way to refactor this or rewrite it in PHP, I’d really appreciate a hand. (I don’t know how to access EE variables in PHP, or I’d try that.)
    Thanks in advance!
    {exp:weblog:entries status="top menu|main menu|open" show_future_entries="yes" disable="categories|member_data|pagination|trackbacks|comments"}
    ... hello world! This line won't show if the conditional is too long.
    {if (>>>weblog_short_name!="board-minutes" AND <<<weblog_short_name!="board-only" AND weblog_short_name!="providers-only" AND weblog_short_name!="staff-only")
    OR ((member_group==1 OR member_group==5 OR member_group==7))
    OR (>>>(weblog_short_name=="board-minutes" AND member_group==6)<<<
    OR (weblog_short_name=="board-only" AND member_group==6)
    OR (weblog_short_name=="providers-only" AND member_group==9)
    OR (weblog_short_name=="staff-only" AND member_group==8))}
    ... show body text of page
    {if:else}
    ... not logged in or unauthorized
    {/exp:weblog:entries}
    [Mod Edit: Moved to the Technical Support forum]
  • #2 / Aug 15, 2009 1:13pm
    mikec964
    I was going to try my hand at a PHP rewrite and I realized my template had PHP input processing on.
    When I disabled PHP processing, the conditional began working.
    My page has no PHP in it anyway, so I’m without any idea of why this was a problem.
  • #3 / Aug 15, 2009 4:56pm
    Greg Aker
    So this was only borking on you when PHP was enabled in the template?  What if it’s set to output?
    -greg
  • #4 / Aug 15, 2009 10:56pm
    mikec964
    Ugh. It broke again.
    I PHP on again and the template continued working. Then I changed PHP from output to input and it continued working. I turned PHP off and on and it continued working.
    I keep my templates under version control, so I thought I’d try an earlier version of the conditional to see if it’d work. The template broke.
    I used version control to roll back to the working template (I store them on the file system), and it still no longer worked. I turned PHP off and on, from input to output. I can’t get it to work anymore.
    Now I’m baffled again AND my page is broken.
  • #5 / Aug 16, 2009 10:19am
    mikec964
    Should I open another thread to report the EE bug that prevents it from processing long conditionals? And keep this one open for refactoring my code as a work-around, or rewriting it in PHP?
  • #6 / Aug 16, 2009 10:50am
    mikec964
    Why does adding three lines of PHP cause the entire {exp:weblog:entries} section to not display?
    This is my first PHP script, so I’m sure it’s something obvious.
    Here are the three lines that broke the script:
    if ($tGroup == 1) {
        echo "Still okay."
    I have PHP parsing on output.
    Here’s the working code:
    <?php
    // must parse on output for $tWeblog to be assigned correctly
    echo "\n<!-- \n";
    $tApproval = false;
    $tWeblog = "{weblog_short_name}";
    echo "This weblog is $tWeblog. ";
    if ($tWeblog == "course") { echo "Is course.\n"; }
    if ($tWeblog != "board-minutes" AND $tWeblog != "board-only" AND $tWeblog != "providers-only" AND $tWeblog != "staff-only") {
        $tApproval = true;
        echo "Approved (not a private page). \n";
    global $SESS;
    $tGroup = $SESS->userdata['group_id'];
    echo "The member group is $tGroup. ";
    if ($tGroup == 1 or $tGroup == 5 or $tGroup == 7) {
        $tApproval = true;
        echo "Approved (in a privileged group). \n";
    echo "Final approval is $tApproval. ";
    echo "\n-->\n";
    Here’s the non-working code:
    <?php
    echo "\n<!-- \n";
    $tApproval = false;
        $tApproval = true;
    global $SESS;
        $tApproval = true;
    if ($tGroup == 1) {
        echo "Still okay."
    echo "\n-->\n";
  • #7 / Aug 16, 2009 1:50pm
    Greg Aker
    How is it not working?  Do you have a link to where that is going on?
    ETA:  What version and build of ExpressionEngine are you running?  Do you have any extensions installed?
  • #8 / Aug 16, 2009 3:23pm
    mikec964
    When I add those three lines of PHP, then the outer {exp:weblog:entries} “fails” and nothing enclosed within it is displayed.
    This is similar to the failure mode when the EE advanced conditional was too long; it causes the enclosing :entries to evaluate to blank.
    I’m running EE 1.6.7.
    Modules: Freeform, Structure
    Extensions: LG Tiny MCE, LG Addon updater, Gypsy, File, Checkbox, Sarge, Moxiecode Authentication
    http://www.acrefamily.org/dev/index.php/training/cpr/
    Use afcc/stage75 to get into the staging area. (There’s nothing private there.)
  • #9 / Aug 16, 2009 3:29pm
    Greg Aker
    can I have you disable extensions with the green button at the top of Admin -> Utilities -> Extensions Manager so we can take them out of the equation for the time being.
    -greg
