I also like to use Aptana because it is more easy to use and install easily. It is compatible with any operating system
May 22, 2009 6:09pm
Subscribe [16]#16 / Jul 10, 2010 8:15am
#17 / Aug 21, 2010 10:42am
Visit this address you may get how to configure aptana for PHP http://docs.aptana.com/docs/index.php/Configuring_PHP_Preferences
#18 / Aug 21, 2010 12:28pm
@Sergio Loza Thanks, your technique worked for me (using Zend Studio 7.2, which is based on Eclipse)
#19 / Apr 30, 2011 8:49am
Am using Zend Studio 8.0, and CI 2.0 on windows 7 With Wamp server…
Not able to get autocomplete…
$this->load->....
Can you show how u did in zend….
#20 / May 01, 2011 6:28am
@rajeev I copied Sergio’s code, which is on page one of this thread. Anyway, that will not work in CI 2.0, since it no longer has base4 and base5 classes. I haven’t tried to get it to work with 2.0.
#21 / Dec 23, 2011 9:52am
I use and suggest free PHP IDE - Codelobster PHP Edition with special CodeIgniter plug-in.
($25)
Hi! danmontgomery, Just register on the site and get free lisence :D
