Alphabetical group listing (A-E, F-J etc) and sorting?
May 21, 2009 6:50am
Subscribe [4]
  • #1 / May 21, 2009 6:50am
    LucPestille
    I’m trying to create a 5 column, alphabetically split, list of the artists I’m creating in a weblog, but the logic escapes me. If it were split by A,B,C,D etc, it would be easier (and I’ve seen threads on that), but the logic escapes me on how to do this variant of it;
    I want to split the list into 5 columns, A-E, F-J, K-O, P-U, V-Z, and be able to sort by firstname/surname - has anyone done something similar, or can help me with the logic/php behind it? Is it better to have one {exp:weblog:entries}, and loop in php, or use 5 custom queries?
    {embed="embeds/above_content" location="artists" opt_page_title="Artists"}
            <div id="artists-header">
                <h1>Artists</h1>
                Sort by <a href="http://?sort=firstname" class="list-sort">Firstname</a> or <a href="http://?sort=surname" class="list-sort">Surname</a>
            </div>
            <div class="artists">
                <h4>A - E</h4>
    <p>            <ul><br />
                {exp:weblog:entries weblog="artists" disable="categories|member_data|pagination|trackbacks" sort="asc" orderby="artist_firstname" }<br />
                    <li class="clearfix"><br />
                        <a href="#" class="more-info">more</a><br />
                        <a href="http://{url_title_path=artists/artist}" title="{artist_firstname} {artist_surname}" class="artist-listing">{artist_firstname} {artist_surname}</a></p>
    <p>                    {reverse_related_entries id="artist" limit="1"}<br />
                        <div class="art"><br />
                            <div class="art-container"><a href="http://{url_title_path=gallery/art}">_                        {exp:imgsizer:size image="{artwork}" width="180" height="110" alt="{title}"}</a><br />
                            </div><br />
                        </div><br />
                        {/reverse_related_entries}</p>
    <p>                </li><br />
                {/exp:weblog:entries}<br />
                </ul><br />
            </div></p>
    <p>{embed="embeds/below_content"}
  • #2 / May 24, 2009 2:40pm
    Rob Allen
    I’d first look at this by using categories for the A-Z, the use Dynamic parameters to allow sorting of entries.
  • #3 / May 24, 2009 4:27pm
    LucPestille
    I don’t particularly want to use categories for something that’s already filled in - it seems odd to me, and will be equally odd to the client “You meant I have to Fill in ‘Adam’,‘Davison’ AND tick ‘A’ AND ‘D’?” Surely there’s a better way, even if it involves some php?
  • #4 / May 24, 2009 6:27pm
    Rob Allen
    If you don’t want to add new data to your entries then you’d probably need some custom scripting as you suggest.
    There are other ways to do this but they it does involve creating a new custom fields and adding data.
    Sometimes to add functionality you have to bite the bullet 😊
  • #5 / May 24, 2009 7:48pm
    AJP
    Look around the forums for the a-z plugin. But depending on what you’re looking for, you might have to custom code a plugin for it too.
  • #6 / May 25, 2009 5:59am
    e-man
    If you want sortable data without page reloads it might be worth it to go with tables and then use something like Tablesorter for jQuery: http://tablesorter.com/docs/
  • #7 / May 25, 2009 6:45am
    LucPestille
    I can live with the page reload for sorting - it’s just 2 options for sorting - it’s getting the data in the right structures first that’s the problem!
  • #8 / May 25, 2009 7:10am
    Rob Allen
    For filtering and sorting entries, Dynamic Parameters might be useful
  • #9 / May 27, 2009 6:31am
    LucPestille
    FYI - I solved it by adding categories for firstname/surname initials, and opting people in to their relevant categories. It’s a long winded way of doing it, but it does work as I wanted it to. Last thing I need is a radio button replacement for the category selection, so people can’t be put in 2 surname categories by mistake - does something like that exist?
                <h1>Artists</h1>
                Sort by <a href="/artists/firstname" class="list-sort">Firstname</a> or <a href="/artists/surname" class="list-sort">Surname</a>
            </div>
    <?php
    //get sort order from querystring
    global $IN;
    $sort_order = "";
    $sort_asc_desc = "";
    if ( sizeof( $IN->SEGS ) >1 ){
    $sort_order = $IN->SEGS[2];
    //set defaults (same as firstname)
    $orderby = "artist_firstname";
    $categories_ae = "25|26|27|28|29";
    $categories_fj = "30|31|32|33|34";
    $categories_ko = "35|36|37|38|39";
    $categories_pu = "40|41|42|43|44";
    $categories_vz = "45|46|47|48|49|50";
    $sort_asc_desc = "asc";
    // if we're ordering by firstname, set orderby and categories for columns
    if ( $sort_order == "firstname" ){
    // if we're ordering by surname, set orderby and categories for columns
    if ( $sort_order == "surname" ){
        $orderby = "artist_surtname";
        $sort_asc_desc = "desc";
        $categories_ae = "51|52|53|54|55";
        $categories_fj = "56|57|58|59|60";
        $categories_ko = "61|62|63|64|65";
        $categories_pu = "66|67|68|69|70";
        $categories_vz = "71|72|73|74|75|76";
                <h4>A - E</h4>
    <p>            <ul><br />
                {exp:weblog:entries weblog="artists" category="<?php echo $categories_ae; ?>" disable="member_data|pagination|trackbacks" sort="<?php echo $sort_asc_desc; ?>" orderby="<?php echo $orderby; ?>" }<br />
                            </div><br />
                        </div><br />
    <p>                </li><br />
                </ul><br />
            </div></p>
    <p>        <div class="artists"></p><h4>X - X</h4><p></div><br />
            <div class="artists"></p><h4>X - X</h4><p></div></p>
  • #10 / May 27, 2009 6:44am
    e-man
    Nice solution. Fieldframe has a radio group option but alas not for categories:
    http://brandon-kelly.com/apps/fieldframe
