input->post() and the "isset()" function
April 20, 2009 12:50pm
  • #1 / Apr 20, 2009 12:50pm
    jinfusion
    All,
    The following code:
    if(isset($this->input->post('foods')) && $this->input->post('foods') == '0')
                    $_SESSION['error'] = "<div class='error'>You must select something from the Foods menu.</div>";
                    $this->select_food();
    produces the following error:
    Fatal error: Can’t use method return value in write context in {path to file…} on line 126
    Line 126 is the first line, the IF statement.
    Is there a way to check the post vars in CI other then just accessing the POST superglobal directly? (which does not produce the error), I like to stay within the framework where possible for clarity’s sake.
    Joel
  • #2 / Apr 20, 2009 1:06pm
    garymardell
    $this->input->post(‘some_data’);
    The function returns FALSE (boolean) if the item you are attempting to retrieve does not exist.
    From the userguide. So you need not use the isset function and just see if it is not false.
  • #3 / Apr 20, 2009 1:56pm
    jinfusion
    Brilliant! Thanks. I forgot how well thought out these things are in CI.
  • #4 / Apr 20, 2009 2:52pm
    guidorossi
    I think you should use the form validation class for this.
    Something like
    $this->form_validation->set_rules('foods', 'Foods', 'required|callback_value_check');
    and then
    function value_check($str)
            if ($str == '0')
             $this->form_validation->set_message('value_check', 'You must select something from the Foods menu.');
                return FALSE;
            else
                return TRUE;
  • #5 / Apr 20, 2009 3:43pm
    jinfusion
    This is a modal dialog not triggering postbacks. I have had some trouble getting the last leg (no view) to work right so I decided to roll my own. I would be glad to see an example of a asynchronous multi stage wizard with the Validation class.
  • #6 / Aug 07, 2014 2:51pm
    dalirnet
    if($this->input->post('search') != false)
         // isset true
