hi, i have a simple search embed which used to work on my devbox, i moved my site to a staging box and my search embed contains weird or old code perhaps. Note, it only appears on some templates, other templates are fine. To illustrate, here’s the old code showing in one template on render:
<h2>Search</h2>
<p><form method="post" action="http://localhost/Xengine/index.php" ><br />
<div><br />
<input type="hidden" name="ACT" value="19" /></p>
<p><input type="hidden" name="XID" value="6fa76e9feeb7ac293700bea6e1a102e985d1fafd" /><br />
<input type="hidden" name="RP" value="search/results" /><br />
<input type="hidden" name="NRP" value="" /><br />
<input type="hidden" name="RES" value="" /><br />
<input type="hidden" name="status" value="" /><br />
<input type="hidden" name="weblog" value="" /><br />
<input type="hidden" name="search_in" value="everywhere" /><br />
<input type="hidden" name="where" value="all" /><br />
<input type="hidden" name="site_id" value="1" /><br />
</div></p>
<p>here's the good code rendering on other templates:</p>
<p> </p><h2>Search</h2>
<p><form method="post" action="http://192.168.1.15/demo/index.php" ><br />
<div class='hiddenFields'><br />
<input type="hidden" name="ACT" value="19" /><br />
<input type="hidden" name="XID" value="2ec98a1f70ef5f6db6149c2e882fe0f627e6fa0c" /><br />
<input type="hidden" name="RP" value="demosite/results" /><br />
<input type="hidden" name="RES" value="" /></p>
<p><input type="hidden" name="status" value="" /><br />
<input type="hidden" name="weblog" value="Dependable" /><br />
<input type="hidden" name="search_in" value="titles" /><br />
</div>and the embed on all templates is:
{embed="demosite_embeds/search"}my actions: 1. cleared all cached data
2. re-saved the suspect template/s
3. cleared all revision history of embed template
4. ran out of ideas :(
thanks for any help,
ray
