Hm- scribefire was a little quirky, but I did get it working. It did through the js error on me once. And playing with it, it seems like it only using one content field- may be why you’re not seeing the content? I went into my metaweblog settings basically select the same field for each of the ‘content/excerpt/more’ and they started showing up. Unless there’s a setting I’m not seeing, it puts everything in whatever is set for ‘content’- I think it was content. Anyway, I think that’s why it’s not showing the field data.
The js error I triggered once I couldn’t replicate. But I don’t think a js error would be due to the EE code. Might see if they have a forum/support and ask there.
But if you’re good posting to a single field, I think Scribe should work.
Haven’t tried blogdesk yet, though was checking out marsedit yesterday. It worked fine aside from a bug we did spot- with the comment url link. A fix is now in for that.
Will give blogdesk a shot, see if I can spot what you’re running into.
ETA- never mind! Looks like Sue got it spotted.
