Hi All,
I have a weblog which contains the names of manufacturers and in order to be able to select the name of a manufacturer from a drop down list while making an entry in another weblog I have set up a custom relationship field which is populated by the manufacturers weblog. When creating a new entry in the second weblog I get the drop down populated as I wanted so no problems there, however when trying to view any entries through a template I just get a 0 where the text should be.
The code I am using to try and display the content from a weblog entry is as follows:
{exp:weblog:entries weblog="vehicle" orderby="date" limit="15"}
{related_entries id="manufacturer"}
<h1>{manufacturer}</h1>
{/related_entries}
