Weblog Entry Vanished?
November 06, 2008 3:54pm
  • #1 / Nov 06, 2008 3:54pm
    BlackHelix
    This is truly Odd.  So I’m editing my weblog entry.  It suddenly disappears from the front end of the site.  I can’t get it to come up at all now.  The weblog entries tag is returning a “no results” result.
    I’ve cleared caches, and as far as I know am on the latest versions.  I’m running MSM.  Thing is, it was showing up.  It shows up on the admin side just fine—I can edit, etc.  All my text is there.
    I created a test template with nothing but the weblog tag on it, so nothing would be interfering.  Still doesn’t show up.  All the other entries in that weblog show up, too.  Just not that one.  If I use the specific entry id parameter, I get zilch.
    I don’t have the foggiest idea what could be causing it.  Here’s my test template in it’s entirety:
    {exp:weblog:entries weblog="static" entry_id="31"}
    {title}
    {summary}
    {body}
    <hr>
    {/exp:weblog:entries}
    <hr>
    {exp:query sql="SELECT COUNT(*) AS my_count FROM exp_weblog_titles WHERE weblog_id = '8'"}
    There are {my_count} entries.
    {/exp:query}
    The query plugin is pulling the correct number of entries, but it just won’t show up!  The debugging says the weblog entries call is sending back a “no results content”; which is truly iffy.
    Test page: http://www.canterburyresume.com/index.php/home/test2/
    On the home page there, you’ll see that the other four entries are being pulled just fine, but the main content is totally not coming in.  And it was before—I saw it there, and I didn’t adjust any settings that I know of.
    Edit:  now it shows up?  I did nothing at all!  But my original problem is still there—the quote marks (plurals) are being borked by the XHTML settings, I think.
  • #2 / Nov 06, 2008 5:40pm
    Let’s tackle one problem at a time, shall we? About the only thing that I could think of would have been a change in status, say from “open” to “closed”. You say it’s all working now, though?
  • #3 / Nov 06, 2008 5:50pm
    BlackHelix
    Yes, it is all working now.  Odd.  It disappeared without warning and appeared without warning.  And for about twenty minutes it just didn’t show up.
    I didn’t change the status at all, but I checked for it once and it didn’t seem to affect anything.
  • #4 / Nov 06, 2008 5:54pm
    OK, I’ll close this thread, then. Please start a new one for separate issues, thanks.
