Hi.
I have a feeling this is an easy one:
I’d like to move several of my entries from Blog A to Blog B. In the control panel when I click on Edit Entry > Options, I can see under “Weblog” that I SHOULD have the ability to switch blogs right then and there.
The problem is my newly created “Blog B” does not show up in the drop-down choices. This is a simple setting, somewhere, right?
Please help.
-Chris
