Hi all, not sure if this should be installation or technical support, but either way, i have an issue with the forums on a site, after moving it from one server to another. I haven’t had too much to do with Expression Engine for a while now, so I am a bit rusty, butalso it is making it difficult for me to work out what the problem is.
The site in question is http://www.stawa.net, the forums are http://www.stawa.net/index.php/forums which is the page that totally gives the errors.. I have had a look at the theme files, and they are in place, and i have also gone into the admin and checked to see that the templates are there and they are.
Is the issue to do with physical files, or is there some other reason behind this?
Any help would be very much appreciated
Patrick
